Winch For Pulling A Mini Up A Steep Drive.
43 replies to this topic
#31 rally1380
rally1380
  • 1,893 posts
Posted 12 September 2014 - 02:38 PM
 The simplest solution would be to get some old mattresses or seat cushions, for padding, and push it with another vehicle.
Would you push a 71 clubman with another car only seperated with a mattress!!!?
Yes, I'm assuming you've pushed it with your hands or backside on a much smaller contact area.
Yes on strong seams or convex areas that won't deform.
If you push a mini up a steep slope using another car, the force will be taken by the bumper seam and I guarantee it will deform under such methods.  And then there is the car pushing it...being modern and not broken, if the mattress was to slip then a plastic bumper would get quite badly damged from an oldschool metal effort.
Not great advice and I wanted suggestions on winch systems, not a Scraphead challenge method.
#32 rally1380
rally1380
  • 1,893 posts
Posted 12 September 2014 - 02:40 PM
I would spend the £100 on the Mini, making it nice and reliable.............
I rally, so if something major goes bang or I have a big accident then I need a way of hoisting the car up the drive and cannot rely on its own power.
#33 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 September 2014 - 02:57 PM
A long time ago I had one of these attached to my trailer...
http://www.ebay.co.uk/itm/321512661302
That managed to pull a mini van with 4 flat tyres, two of which were not rotating from the bottom of a steep drive where it had been parked for at least 10 years....
Attached File  27092007191.jpg   50.86K   5 downloads
but what I would also get is something like this as you'll be a long way from the winch...
http://www.ebay.co.uk/itm/191271449638
#34 Ethel
  • 26,141 posts
Posted 12 September 2014 - 04:35 PM
Well that's me told  :ohno:
It need only be as scrapheap challenge as you make it. Fashioning a Mini pushing yoke will be no more effort, and a lot cheaper than fitting out your garage with a winch, it could also be as portable as your recovery vehicle.
#35 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 12 September 2014 - 05:06 PM
That made me chuckle, not least because I had a vision of  firing a large heavy object down the drive attached to a rope which pulled the Mini back up the slope in the opposite direction. Haven't quite figured out how you manage to avoid the two objects colliding yet, but lets call this the Mr Bean variant solution.
I'm guessing these suggestions are best left to the off topic banter section and I will issue myself a warning point.  O_O
#36 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 12 September 2014 - 05:08 PM
I feel a Fosters Friday thread coming on.....
#37 DrGoatboy
DrGoatboy
  • 27 posts
Posted 12 September 2014 - 06:31 PM
Have a look on the toolstation website for pull winch. Less than 30 notes and rated at 4000kg. Perfect!
#38 rally1380
rally1380
  • 1,893 posts
Posted 12 September 2014 - 06:48 PM
Been there, bought that and took it straight back.  It did promise so much but is total garbage and wouldn't release under pressure.
#39 rally1380
rally1380
  • 1,893 posts
Posted 12 September 2014 - 06:50 PM
Bring on more suggestions like that.....certainly more sensible than some.  Would love to see my stuck up neighbours face with an idea like that.
#40 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 12 September 2014 - 07:18 PM
I haven't checked the maths for a 30 degree slope yet, so use with caution  O_O
#41 100ev8
100ev8
  • 622 posts
Posted 12 September 2014 - 11:12 PM
a pulley in the garage and a rope ? mini to pulley back under mini tied to another car and pull it up ? cheap and cheerful but works
#42 Ethel
  • 26,141 posts
Posted 13 September 2014 - 12:40 PM
An issue with winching will be getting a line of sight or friction free pull. You'll either need the winch mounted high enough  in the garage for a straight cable to run to the car, or a secure roller on the apex where the garage floor meets the slope.
I'm liking M&P's idea, it'd automatically turn yer Mini round so you don't have to reverse down the drive - bonus!
#43 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 13 September 2014 - 02:10 PM
or if you do it this way all you need is an anchor point / tree / etc
I'll stop now  :D
#44 woodley miniman
woodley miniman
  • 304 posts
Posted 14 September 2014 - 03:10 PM
How about this
http://www.screwfix....equestid=153704
It might be the sort of thing your after and a good price too!
