Mr3Speed's Austin Mini
#181
Posted 27 October 2015 - 07:15 PM
Old failed seal
Also changed out for a electronic indicator flasher. Fed up of the Mini spares ones failing. Had some turn up faulty from new, cheap made and seem to just fail. Added this and i now have a modern flash rate. Small thing but looks good when indicating!!
#182
Posted 25 November 2015 - 09:58 PM
The carb, well jet saga
When it went for a MOT it had a slight drip from the jet. To get it through one on the boys covered it in silicone. All over the spring and line. Stuck them together.
I had to replace the seal but now had the whole lot stuck together. I used some silicone remover to soften and get the silicone off. Absolute nightmare, the spring was solid. Anyway in using the silicone remover it softened the fuel line. Little Eric started running badly, in my garage carb off again.
As the line had silicone remover on it, it caused the end with the new seal on to collapse in on its self and totally cut off the fuel supply. Ive had to put a brass collar in the seal end, larger than the standard one to stop it collapsing in on its self. Eric now runs again
#184
Posted 28 November 2015 - 09:30 PM
#185
Posted 29 November 2015 - 08:25 PM
#186
Posted 04 December 2015 - 11:08 PM
Dispite everything ive said does Eric get a new lease of life. Converted tona manual 1380 fast road set up or do i get another shell. This always happens. “Ill leave it alone” racecar!
#187
Posted 05 December 2015 - 09:19 AM
Great looking mini, and in the hands of the right owner who is appreciating it. Personally I think is sitting a little low at the back (but only my opinion) I would say keep all the mods subtle as a car that has survived this long (35 years) and this well preserved deserves to remain that way. I personally feel there are plenty of poorly modded / molested minis out there to save. You see them all the time on ebay. I love the stripy interior and details like this keep getting rarer, Keep up the good work.
#188
Posted 18 January 2016 - 03:29 PM
#189
Posted 05 February 2016 - 07:11 PM
New lowered dampers ordered for little Eric. May see if ive got time to get them on this weekend
Edited by mr3speed, 05 February 2016 - 07:12 PM.
#190
Posted 09 February 2016 - 07:50 AM
#191
Posted 29 April 2016 - 06:46 PM
Eric is now a 1380 manual. Huge update soon but here he is as of now
https://youtu.be/IydzIHQEmYY
#192
Posted 30 April 2016 - 01:48 PM
What rpm was he taking it to ?
#193
Posted 02 May 2016 - 05:49 PM
6000
#195
Posted 21 October 2016 - 07:16 AM
Flipping love this thread, so old skooooool !!! any new updates coming?
Have you thought abut fitting spacered mini-fin drums on the rear and cooper-s discs on the front?
Jamie.
