Engine Rattle
Best Answer minimk1 , 12 October 2014 - 04:27 PM
Found the solution I took my car for a rolling road at peter baldwins and he said it was the camshaft plate, sure enough swapped it out for a new one and she purrs like a kitten so happy
Go to the full post
Posted 20 September 2014 - 06:54 PM
I fitted a new clutch less than 100 miles ago
The timing chain is new and is the duplex version
New clutch release bearing and shaft
Tappets have been checked 3 times and are all spot on
I have no idea what is causing this but my car now sounds like a transit when idling and it is slowily bothering me more and more
Any ideas would be helpful
Harry
Posted 20 September 2014 - 06:58 PM
could be the transfer gears or primary drive gear?
Posted 20 September 2014 - 07:01 PM
If it was these how damaging is it ? As I will be changing for a 1275 within a year
Edited by minimk1, 20 September 2014 - 07:02 PM.
Posted 20 September 2014 - 07:04 PM
Posted 20 September 2014 - 07:18 PM
It looks as though there is a lot of smoke or steam coming from the exhaust. I'd be inclined to say something like headgasket problems as this can cause horrible knocking noises. Hard to tell from the video.
Edited by Stiggytoo, 20 September 2014 - 07:18 PM.
Posted 20 September 2014 - 07:33 PM
Posted 20 September 2014 - 07:35 PM
Posted 21 September 2014 - 12:06 AM
Hi
you say The timing chain is new and is the duplex version
has it allwase been ?
or have you just fitted duplex ?
Posted 21 September 2014 - 08:48 AM
It started after a 30 mile trip at around 60mph which is the engines first long run after the resto so could it be something to to with that ? I belive it could be the idler bearing but it makes the same sound in gear so I am unsure.
Keep the comments coming need to figure out what this is as I have a rolling road booked, however if it is critical then I will have to cancel this
Thanks harry
Posted 21 September 2014 - 09:00 AM
I thought it was the idler gear to when you said it stopped when you pt the clutch in.
Posted 21 September 2014 - 09:14 AM
Posted 21 September 2014 - 10:04 AM
Hi
when you fitted the duplex
did you counter sink the 2 bottom holes
and fit counter sunk screws
if not the chain is hitting the bolts
Posted 21 September 2014 - 11:08 AM
If it goes away when you press the clutch then its beyond the clutch plate, i.e when the car is in neutral with the engine running the transfer gears are turning press the clutch and your not driving the transfer gears so probably the idler gear rattling which is quite common, were the transfer gears shimmed to spec?
edit - Could be the timing plate bolts as above if the crank thrust washers are knackered and your pushing the whole crank towards the rad, then the bottom pulley would clear the bolt heads. I'd imagine it would make a noise relative to the crank speed.
Edited by The Principal, 21 September 2014 - 11:14 AM.
Posted 21 September 2014 - 12:40 PM
The problem is there weather the clutch is depressed or not, Stumped for ideas
Other than this the car runs perfectly so I'm pretty gutted with this noise
Transfer gears are factory spec I only did a clutch change and a new cam, nothing else was dismantled as the engine was in my car before and ran fine
Posted 21 September 2014 - 12:56 PM
is it something daft like a rocker hitting the rocker cover?
