Underbody Sealing
37 replies to this topic
#1 frosty90
frosty90
  • 199 posts
  • Local Club: Mini Bitz
Posted 01 October 2014 - 11:21 AM
Hi All,
Getting ready to clean up the underneath the mini and seal everything.
What is recommended these days? Ive always just painted with hammerite and then wayoyled in the past.
But ive read a lot about hammerite not being that good anymore.
Also what is the best procedure? so stone chip paint order...
#2 Covert
Covert
  • 526 posts
Posted 01 October 2014 - 11:32 AM
Gravitex stone chip
#3 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 01 October 2014 - 11:52 AM
Upol Raptor truck bed liner is superb!!! 2k product and very hard wearing.
#4 frosty90
frosty90
  • 199 posts
Posted 01 October 2014 - 12:25 PM
should have added I don't have a compressor currently but I can borrow one if it is the best method going forward!
#5 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 01 October 2014 - 01:22 PM
Bilt Hamber Dynax.  Google it and then buy some.  The best stuff you can buy!
#6 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 01 October 2014 - 01:27 PM
+1 for Dynax!
Clear
7FC577D9-E8AF-46D2-B6C9-6825C37AF291_zps
Black
864DD860-C0DA-4950-A686-A792CE61A1D3_zps
I would paint it and stone chip it first though. Dynax is your final coat for waterproofness. It is your WaxOyl substitute that doesn't wash off after a month.
Edited by HarrysMini, 01 October 2014 - 01:31 PM.
#7 spritey
spritey
  • 162 posts
Posted 01 October 2014 - 01:33 PM
I can second that upol raptor is the best product once mixed u can actually brush it on if you don't have air compressor , strong hard wearing around 60pound got 4 tubs plus hardner but much better than anything else out there , if u get white u can tint it the same colour as ur car also
#8 frosty90
frosty90
  • 199 posts
Posted 01 October 2014 - 01:48 PM
as far as Dynax goes, which one would people recommend? theres 3 different ones Dynax S50, Dynax UB and Dynax UC
#9 frosty90
frosty90
  • 199 posts
Posted 01 October 2014 - 02:00 PM
also can I stone chip over hammerite does anyone know as I know its the devils work :(
#10 HarrysMini
HarrysMini
  • 3,352 posts
Posted 01 October 2014 - 02:03 PM
S50 is used for internal cavities (sill box sections etc.)
UB is the black one pictured above.
UC is the clear one pictured above.
#11 frosty90
frosty90
  • 199 posts
Posted 01 October 2014 - 02:06 PM
top man I shall be ordering tonight :)
#12 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 01 October 2014 - 06:58 PM
I wouldnt coat anything over hammerite! Its a nightmare and usually reacts unless you are hammeriting over hammerite. As above Bilt Hambers stuff is supreme!
#13 frosty90
frosty90
  • 199 posts
Posted 02 October 2014 - 08:51 AM
this is my worry but i stupidly painted all the rear arches and and back of the car in hamemrite and know its gonna be a nightmare to remove :(
#14 Carlos W
Carlos W
  • 10,114 posts
Posted 02 October 2014 - 09:36 AM
Test a small area and see if it reacts
#15 frosty90
frosty90
  • 199 posts
Posted 02 October 2014 - 10:24 AM
might see if I can get some primer to lay over it first! if not angle grinder and sanding pad should do the trick
