Underbody Sealing
37 replies to this topic
#31 lsto
lsto
  • 606 posts
Posted 11 October 2014 - 08:14 PM
I just waxoyl every year. Worked so far. Worked on my old astra van. Worked on my mates landy.
Each to their own I guess...
#32 miniBrain
miniBrain
  • 192 posts
Posted 14 October 2014 - 10:39 AM
Here's two options I've used in the past:
If you can clean & degrease the underside:
1) Brush or roller with Epoxy Mastic two pack paint as primer - the toughest paint I've ever used and it will stick to anything (unlike POR 15) - two coats.
2) Spray anti-stone chip - I used some from Wayside Adhesives - no problems after 2 years.
3) Spray with body colour.
If you can't clean off the old underseal (or can't be bothered):
1) Spray a light coat of Dinitrol 3125
2) Wait a couple of days for the 3125 to harden and then top coat with Dinitrol 4941
Above all, NEVER use Hammerite on the body. Like people have said it reacts to just about anything non Hammerite. Hammerite is fine on removable items, fuel tank, suspension parts etc.
Edited by miniBrain, 14 October 2014 - 10:42 AM.
#33 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 14 October 2014 - 10:53 AM
One paint I have found that doesn't react with Hammerite is zinc primer. I've just done a wheel arch repair on our Discovery with zinc primer top coated with Hammerite and it went on and has dried really well.
#34 Cooperman
  • 23,317 posts
Posted 14 October 2014 - 11:40 AM
I spray with Schutz, thinned slightly, then spray body colour over the Schutz after it has had around 3 days to fully 'go-off'.
#35 frosty90
frosty90
  • 199 posts
  • Local Club: Mini Bitz
Posted 14 October 2014 - 11:55 AM
cheers guys!! at the moment ive been finding more rust that anything to havint go take a step back and look at the best way forward1
#36 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 14 October 2014 - 06:23 PM
So now we know there's lots of different ways to protect from the tin worm, but I think one of the most important is get underneath at least every year re-coat or at least touch up any suspect areas!
#37 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 18 October 2014 - 07:57 PM
Hammerite can go over other paints but not be coated over with much other than hammerite.
#38 661
661
  • 212 posts
Posted 18 October 2014 - 09:55 PM
Yup. Dinitrol convert here. 4941 sticks like **** to a blanket
Edited by 661, 18 October 2014 - 09:56 PM.
