Rear Subframe
suspension
Best Answer alex-95 , 14 October 2014 - 07:36 PM
It may be beneficial to put a bit more weld on the other nut just incase.
For 1. you can make 3 cuts and then bend the sill back, weld the nut on and weld it back on.
This is a picture of how 2. is done. (sonikk4's pic)
Go to the full post
6 replies to this topic
#1 tefer
tefer
    Just On Tickover
  • 8 posts
Posted 14 October 2014 - 06:45 PM
Hi,
Can anyone help me?
I was putting back the rear sub frame in my mini and when doing up the front mount against heel board one of the threads has come away from the body so there is nothing to bolt up to.  (Theres just a whole with no thread)
Im pretty new to this. Any suggestions please. I have tried to upload a pic but cant... if anyone needs this i can email it to you.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 14 October 2014 - 06:58 PM
You'll have to get into the heelboard to be able to weld one in, there is a few ways of doing this.
1. cut open the outer sill
2. go in from the companion bin, drilling/cutting a hole in the strengener peice to get to it
3. cut the heelboard weld the nut back on and weld that peice in again.
4? I think some people have drilled a bigger hole where the nut come from and welded it back on from the outside.
To upload a pic the best way is to create a photobucket account and copy the IMG code into your post.
#3 tefer
tefer
    Just On Tickover
  • 8 posts
Posted 14 October 2014 - 07:20 PM
many thanks for your advice looks like ive got busy day tomorrow
#4 tefer
tefer
    Just On Tickover
  • 8 posts
Posted 14 October 2014 - 07:34 PM
many thanks gunna be busy tomorrow
#5 alex-95
alex-95
  • 6,017 posts
Posted 14 October 2014 - 07:36 PM   Best Answer
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,903 posts
  • Name: Neil
Posted 14 October 2014 - 08:05 PM
Now to be honest if you cannot weld then the option of cutting a hole in the inner sill stiffener in the companion bin is the way forward here. Much like i had to do to my sons car. Now i can weld but after the expense we both went to in doing his car we needed an easy option and this was it.
Enough room to knock off the captive nut and get a spanner in to fit a new stiff nut.
#7 tefer
tefer
    Just On Tickover
  • 8 posts
Posted 15 October 2014 - 06:26 PM
i think that this is the best option as my welding isnt the best. many thanks for pic a great help looks easier than i thought.                 [ WELL MAYBE ] HAHA. will let you no how i get on
Also tagged with one or more of these keywords: suspension
