Hi
I've been having a few problems with my battery lately. The car drives perfectly but the battery is discharging as soon as the car is turned off. After 5 minutes I can't even start it. What could be using this much battery?
It's an MPI.
Rasmus
1 reply to this topic
Posted 14 October 2014 - 07:49 PM
Posted 14 October 2014 - 07:53 PM
Either your alternator is not charging correctly or your battery is sulphated or both, both the tests are in the electrical section of the FAQs time to get the voltmeter out. There is nothing other than the starter than could drag the battery down that quick.
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
