Posted 16 October 2014 - 09:57 PM
Posted 16 October 2014 - 10:21 PM
On the front you compress the rubber spring cones using a compression tool (known as the Tower Tool), then remove the aluminium trumpet which sits between the rubber spring and the knuckle cup in the top arm.
On the rear you remove the petrol tank, undo the damper each side at the top inside the boot, lower the suspension arm and pull out the long aluminium suspension trumpet.
Replace the trumpets with the Hi-Lo's and re-assemble.
Set the ride height correctly.
This is general information. For more information as to exactly how to take out the aluminium trumpets look at the Haynes Manual or the BMC Workshop Manual.
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
