Another Lynx Kit Racetool Project
20 replies to this topic
#16 Davis23
Davis23
    Starting My Mini Up
  • 2 posts
Posted 12 January 2015 - 11:40 AM
Hi Chris,
I'm Marc and I live in Bern. I also have a converted Mini with Lynx AE kit. I'm now adding an electric engine (with Lithium Batteries) to compensate the poor torque of the Yamaha engine and reach 170PS.
I have had several problems with my conversion which is now working not so bad. As I live one hour far from you it could be great to exchange our experiences. Give me a call if you want: 0041 76 398 90 20.
Best regard,
Marc
#17 Helldriver
Helldriver
  • 101 posts
Posted 14 January 2015 - 01:56 AM
Hi Chris,
Best regard,
Marc
Hi Marc,
That is great news. Exchange is very welcomed.
Also interesting what you want to with the electrical engine. My plan is to add a supercharger for more torque.
Will give you a call next days.
Best
Chris
#18 Helldriver
Helldriver
  • 101 posts
Posted 08 May 2015 - 02:52 PM
news....
Engine with lynx cradle is in. looks all go after I figured I need the original engine mounts which lifts the engine 3cm up and clears the gear selector :-)
BUT: swiss motor book for the car specs will change due to FIA rules adaptions next year and it will require a mechanical reverse gear if I want to start at swiss races which the lynx doesn't have. So I am forced to change to promotive which has the mechanical reverse if I want to stay with the R1 which I will do. Sucks but luckily I didn't buy the whole lynx kit, so I can still switch without too much hassle...
I luckily got a very cheap a not used overcomplete promotive kit incl. 5pw engine with less then 10K on it (R1 5PW engine no. 4 :-) in my collection)/K&N Filter/Barnett clutch/ready to fit loom/5pw clocks so I will switch to promotive side and fix the low sump clearance by staying on 13inch wheels.
Thanks god I just bought the lynx cradle, the silicone hoses and electric reverse gear, which is up for sale now, PN me if you are interested.
Edited by Helldriver, 08 May 2015 - 03:15 PM.
#19 duds100
duds100
  • 231 posts
Posted 11 May 2015 - 10:28 AM
...Bargain on the pro-mo kit!
#20 The Elfman
The Elfman
  • 25 posts
Posted 13 May 2015 - 04:21 PM
What size chain do they use as the drive is very short ? 530 or bigger ?
Edited by The Elfman, 13 May 2015 - 04:22 PM.
#21 duds100
duds100
  • 231 posts
Posted 13 May 2015 - 04:46 PM
Yeah 530 pitch chain. Pro-motive Front sprocket is a yamaha R1 front sprocket. Pro-motive Diff sprocket is a suzuki busa front sprocket. Chain runs around these 2.
Loads of sprocket sizes available so a pretty wide scope available in terms of gearing.
