Check this link again...
Garret says it needs 40-45PSI at max revs.
If you're getting 40PSI at idle then you are well over Garrets recommendations for pressure when the engine is revving. Sure, your drain may not be optimal, but if you can lower the feed pressure with a restrictor, and increase the crankcase breathing, that might be all you need to do.
EDIT: yeah I'm always editing my posts. It's a bad habit of mine
Edited by chrome, 24 November 2014 - 12:02 PM.
