Thread revival, sorry in advance but I'm having a very similar issue..
Car will rarely start due to turning over very slowly most mornings. The problem has only reared it's ugly head in the last few weeks and first thought was the battery. Replaced the battery as the one that was on there was very old. This worked and the car flew into life for a few days but went back to slow cranking and the battery eye has turned black, the guy in Halfords said they ignore this as they aren't reliable but I'm a bit dubious of that.
We've cleaned up and moved the earth off the engine and tried a different starter motor that gave exactly the same problem. The car starts fairly easily with a jump start but often is too slow to start from cranking it over however sometimes doesn't start even if it is cranking over well. Have also got the timing and mixture properly set up as they were a fair bit out but the problem stays. Is it worth replacing the battery lead through the car as have heard this could be the problem or is the alternator draining the battery as the car sits there as often the car will start fine one night then the next morning the problem arises and won't start. Just to add, the car runs like a dream when it actually does burst into life.
If anyone could help it would be much appreciated as it's driving me to my wits end! Thanks.
