yet more brake problems.
#16
Posted 11 July 2006 - 03:34 PM
#17
Posted 11 July 2006 - 03:47 PM
#18
Posted 11 July 2006 - 03:49 PM
#19
Posted 11 July 2006 - 04:38 PM
DO NOT WASTE YOUR TIME OR MONEY ON ANYTHING ELSE
Same goes for what i said last year and you wouldn't be in this situation. But hey hope you get it sorted soon.
#20
Posted 11 July 2006 - 05:33 PM
Dont even think about editing that, Jammy.
Edited by jack_marshall, 11 July 2006 - 05:34 PM.
#21
Posted 11 July 2006 - 05:40 PM
I recently changed the brakes on a old 1976 Landrover, that certainly had different brake pipe connector threads, I had to change the lot to fit the new cylinders.
You could also be getting air back in through the bleed valve threads if they are 100% secure fit.
Finally check your flexible hoses if at all suspect fit braided ones. I had a similar problem with a clutch - fitted new plates, thrust bearing, master cylinder, operating arm only to find fluid was passing from the inside of the flexible pipe to a cavity between the outer braid and the inner pipe under pressure. Get someone to apply the brake while you hold the flexible hose tight to feel if it expand or moves unduly.
Good luck. If all else fails spend money!
#22
Posted 11 July 2006 - 09:08 PM
if its not that then the only thing it could be is the master bugger meaning 30 squid + of cash i do not own going bye bye.
oh well. also. pressuure sencor thingy on the master cylinder. is there some trick to getting that out?
#23
Posted 11 July 2006 - 09:13 PM
so i built up pressure and left the pedal down for the night.
Did you leave the master cylinder cap slack?
#24
Posted 11 July 2006 - 09:27 PM
wait. you having said that means i should have,
#25
Posted 11 July 2006 - 09:35 PM
either you have dodgy mech's or you have a fault somewhere
#26
Posted 11 July 2006 - 09:37 PM
could it be that???
whats the "proper" way to bleed it??
#27
Posted 11 July 2006 - 09:38 PM
#28
Posted 12 July 2006 - 11:21 AM
right, i've had it properly blead by Rory whos a mechanic (also my mum's boyfirend meaning free, woohoo!) blead it all thro. all nice clean air free fluid coming thro and STILL i had to pump it. so the final suspect is air in the master cylinder (please god let it be that) so i built up pressure and left the pedal down for the night.
I used to have this problem on my drum braked mini, I must have put gallons of brake fluid
through the system trying to get a decent pedal.
The trick is to adjust all your brakes up so that they rotate stiffly by hand, ie much tighter than
is described in the haynes manual. I used to have a couple of high spots on the rear brakes and
had to adjust these so I could _just_ rotate the wheel past them. You'll have to do this fairly
regularly if you want to keep a good pedal.
If this works it might be a good idea replacing the drums.
Nial.
#29
Posted 12 July 2006 - 11:36 AM
errmmm.......no.....should i have?
If you leave the cap tightly on, where is the air going to get out?!
#30
Posted 12 July 2006 - 12:37 PM
still in the EXSACT same condition. no brakes unless you pump it 3 times.
Anymore suggestions on a fix?
