Yeah I found that little bugger hiding earlier so hopefully should go alright
Posted 02 January 2015 - 08:16 PM
Posted 02 January 2015 - 08:34 PM
Loosen it until you see air or water bubbling out.......but be careful I think it can fall out if fully opened and get lost down in the depths of the engine bay like your bottle top/cap if you drop it !!
Edited by mab01uk, 02 January 2015 - 08:37 PM.
Posted 02 January 2015 - 08:40 PM
Edited by megamini_jb, 02 January 2015 - 08:41 PM.
Posted 03 January 2015 - 10:03 AM
Edited by megamini_jb, 03 January 2015 - 10:04 AM.
Posted 03 January 2015 - 10:07 AM
Edited by megamini_jb, 03 January 2015 - 10:08 AM.
Posted 03 January 2015 - 11:08 AM
Posted 03 January 2015 - 11:31 AM
Posted 03 January 2015 - 12:53 PM
If no water/coolant will go in the filler and level fluctuates there must be a trapped airlock somewhere, perhaps loosen a rad top hose to begin with and see if the rad has definitely filled up to the top hose ok?
I said they can be a pig to bleed through for some reason.......
Edited by mab01uk, 03 January 2015 - 12:55 PM.
Posted 03 January 2015 - 01:14 PM
Edited by megamini_jb, 03 January 2015 - 01:16 PM.
Posted 03 January 2015 - 04:21 PM
Leave all of the bleed screws open, make sure the heater is on full hot and with the fan blowing. Close the screws once coolant starts seeping out of them, you may have to remove the expansion bottle from it's fixings and lift it higher than the engine depending on where it's mounted
Posted 03 January 2015 - 05:06 PM
Edited by megamini_jb, 03 January 2015 - 05:07 PM.
Posted 03 January 2015 - 05:08 PM
Edited by megamini_jb, 03 January 2015 - 05:09 PM.
Posted 03 January 2015 - 06:21 PM
This is a quite common problem on R50 MINI's after a coolant drain and refill if you search on google for "coolant bubbling mini2"
I'm not sure there is a definitive answer to the problem when it happens, other than there is air still trapped in the cooling system, the pressure cap seal is also important as the coolant will boil at a lower temperature if the cap does not seal correctly and bubble up into the expansion tank which is unpressurised on the R50......check the seal or replace pressure cap on engine if suspected.
This Mini2 post is helpful:-
http://www.mini2.com...tank-fixed.html
and this was the cap (seal may be damaged when you remove cap after not being removed for some years/months)
"had the same with the 2001 Mini One we bought for my daughter. First afternoon of using it after collecting it from the dealer got home to hear the water 'boiling' in the header tank and immediately thought the worst - head gasket.
The Mini doesn't have a pressurised header tank, the pressure cap is on the engine fill point, looking at the pressure cap there was evidence of coolant leakage so I suspected this might be the cause, the cap releases the pressure so the water boils. When I took the cap off the seal was in pretty poor shape and just twisting it caused it to split so as a temporary fix I made two rubber seals out of a bicycle inner tube to match the thickness of the original and refitted the cap, job done, no more loss of coolant or boiling.
I bought a new cap from the local Mini dealer for around £11 which is now fitted."
http://www.mini2.com...tml#post3818920
From the old MCR Forum:
"On the filling and bleeding, when I had the rad on my R50 replaced by a local speciallist I noticed the sound of trickling water coming from behind the dash. I guessed it was the flow going through the heater matrix. I checked the level in the expansion tank, but all appeared OK, so I opened the bleeds and low and behold some air came out. It took another couple of drives and bleeding sessions to get all the air out of the system and stop teh trickling sound coming from the heater."
http://forum.minicoo...roblems?t=13263
Edited by mab01uk, 03 January 2015 - 06:34 PM.
