Rally Mini Advice On Suspension
21 replies to this topic
#16 rally1380
rally1380
  • 1,893 posts
Posted 11 January 2015 - 09:12 PM
^^^^ Nice welding!!!! Very neat.
I've always thought that your way is correct - think they are like that in Vizards book, but no reason the other way wouldn't work also.
#17 Tupers
Tupers
  • 4,156 posts
Posted 11 January 2015 - 09:35 PM
It's not my neatest work to be honest but each joint was welded on both sides with good penetration and no undercut so they should be plenty strong enough.
#18 rally1380
rally1380
  • 1,893 posts
Posted 11 January 2015 - 10:06 PM
Better than some welding i've seen...you should be very happy with it.
#19 Cooperman
  • 23,327 posts
Posted 11 January 2015 - 11:44 PM
I hope this helps. If you want the full spec of my historic rally 'S' PM me your personal email and I'll send it. It covers 4 pages.
Would you mind if I also send you a PM for a copy please?
Keith
You will be most welcome.
#20 thetrev.com
thetrev.com
  • 84 posts
Posted 16 January 2015 - 07:45 PM
Thanks for all the info lots to digest
#21 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 19 January 2015 - 05:30 PM
Some gussets on the rear subframe in the corners also help as well as a bit of seam welding
Putting some extra weld on the rear top shock mounts also helps
#22 Cooperman
  • 23,327 posts
Posted 19 January 2015 - 06:29 PM
The rear radius arm brackets can fracture from the top (as installed) downwards where the 90 degree bend in the bracket is. To prevent this weld in a small triangular piece of 4 mm steel plate in the corner right at the top.
