Its a HIF38
Can Coils Suddenly Just Die?
#16
Posted 13 January 2015 - 08:25 AM
#17
Posted 13 January 2015 - 12:48 PM
Others will have to advise you on the best way to check and set the float level on HIF carbs. I am much more familiar with HS series carbs.
#18
Posted 13 January 2015 - 01:54 PM
Here you go
Posted 14 January 2015 - 07:46 AM
Thanks I will have a check, weather is not the best at the moment for working outside…. lol
#20
Posted 17 January 2015 - 09:04 PM
Edited by Minigirl, 17 January 2015 - 09:05 PM.
#21
Posted 17 January 2015 - 09:06 PM
had a look, sanded the contacts down inside the dizzy cap until clean as when testing with the contin. meter I was getting poor reading and also the rotor arm, car fired but very very spluttery. When running I tried pressing the accelerator pedal and it was instant stall of the engine.
Also checked the spark from the coil and sometimes it was a orange colour / shade too it, does that indicate a weak spark? Also the sparks ranged from very dull to medium dullness to bright sparks
I have the carb off now as well to look at it.
#22
Posted 17 January 2015 - 09:09 PM
Orange spark does indicate a weak spark it should be a bright blue, have you checked your coil voltage and what coil your running
#23
Posted 17 January 2015 - 10:37 PM
Coil is wired up with a 12 volt feed. The coil is still the Gold Lucas thats reading 2.6 ohms or what ever is was (Im sure it used to be over 3 ohms when I tested it months ago)
Just trying everything before spending money on a coil first
#24
Posted 18 January 2015 - 02:06 PM
#25
Posted 18 January 2015 - 06:09 PM
For the orange spark, try a new condenser (assuming your car has a points ignition system).
#26
Posted 18 January 2015 - 06:18 PM
#27
Posted 20 January 2015 - 06:01 PM
Stuck the carb back on but still not running :-( Will order a new coil and condenser / points or just go for electronic ignition instead of points but might be best to get it running first before going electronic?…
Also going to do a compression test as well would that be worth doing?
thanks
Edited by Steve-O 2014, 20 January 2015 - 06:55 PM.
#28
Posted 20 January 2015 - 09:40 PM
Compression and/or leak-down tests can reveal problems. Definitely worth doing. Remember during the compression test to pull all the spark plugs and hold the throttle wide open while cranking the engine on the starter. It's preferable to do this with a warm engine but I know that's currently not an option.
I agree that it would be best to get the car running on points before moving on to electronic ignition. Try the new points and condenser first. They are less expensive than the coil. While coils do go bad, they don't go bad often. Many times when you press a person who says a new coil fixed their car's problem they will eventually get around to saying that "Oh yeah, I changed the plugs, plug wires, cap, rotor, points and condenser too... but I know it was the coil". Try the cheap parts first.
#29
Posted 20 January 2015 - 10:25 PM
will this kit be ok just to check?
http://www.ebay.co.u...=item1c348c02df
Is there anyway to test the condenser?
Should I change the coil anyway since it is reading the wrong ohms?
#30
Posted 21 January 2015 - 03:34 PM
Compression test
1 - 160psi
2 - 158psi
3 - 156psi
4 - 161psi
