Fusion Fabrications - Bespoke Custom Parts
88 replies to this topic
#61 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 30 April 2015 - 07:16 PM
Thanks Yeti21586.
Here's another turbo setup completed for a 998. This is using a GT1544 turbo which is a nice size for a road spec 998. This has been designed to fit in without the need for a bulkhead box.
Attached File  image.jpg   25.54K   95 downloads
Edited by matty..., 30 April 2015 - 08:07 PM.
#62 matty...
matty...
  • 605 posts
Posted 21 May 2015 - 08:01 PM
I've had a fair few requests for a sidemount setup for the A series and this is the first setup made to customer requirements. I now have a second side mount manifold in progress, which will be for the GT series turbos as a straight bolt on setup.
Attached File  image.jpg   36.55K   47 downloads
Attached File  image.jpg   30.15K   21 downloads
Attached File  image.jpg   33.17K   23 downloads
#63 paulk 7364
paulk 7364
  • 206 posts
Posted 25 May 2015 - 02:47 PM
Hi, can you do a nice inlet manifold for a hif 44
Carb. It's for a 1275 tuning a swifttune sw5 cam
With a brake servo. Would like a good performance up grade.
Thanks paul
#64 matty...
matty...
  • 605 posts
Posted 26 May 2015 - 09:17 AM
Hi Paul, yes shouldn't be a problem making an inlet up. I've made a few inlet manifolds for the the weber setup so an SU setup won't be a problem. If you've got the room between the carb and bulkhead extending the inlet manifold length will improve your low/mid range torque.
#65 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 01 June 2015 - 09:55 AM
Thanks Yeti21586.
How much would something like this cost for a 1275? Might be looking into the turbo route but have no idea what turbo to use and don't want to cut the bulkhead
#66 adcyork
adcyork
  • 490 posts
Posted 01 June 2015 - 12:06 PM
Another shout out for Matt's work here:
5E2EF1C6-FBC6-4ADD-8AE0-0418A4961C52_zps
C2C84BFE-B7DD-4305-B3FC-E41F489CCBB9_zps
#67 matty...
matty...
  • 605 posts
Posted 01 June 2015 - 05:58 PM
I do a standard manifold an downpipe to fit a gt1752 turbo, which is £375 for the complete kit. The above setup was a custom setup for a different turbo, so something like that is £450.
Thanks Yeti21586.
Here's another turbo setup completed for a 998. This is using a GT1544 turbo which is a nice size for a road spec 998. This has been designed to fit in without the need for a bulkhead box.attachicon.gifimage.jpg
#68 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 02 June 2015 - 04:19 AM
mmm...
Edited by Mini Manannán, 02 June 2015 - 04:38 AM.
#69 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 02 June 2015 - 04:37 AM
Hmmm... Praps not...
Edited by Mini Manannán, 02 June 2015 - 11:41 PM.
#70 matty...
matty...
  • 605 posts
Posted 03 June 2015 - 09:01 PM
Hi, mini mananan, Sorry for the late reply, I did read your post, I was just awaiting a costing for the HIF flange before quoting a price. Yes I can make you up a custom inlet like you had shown. I can do this for £175. Thanks.
#71 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 03 June 2015 - 09:54 PM
Cheers Matty, I assumed you hadn't read it.  I had my doubts anout that design after reading another book on inlet manifolds. I'll have another think about it.
#72 matty...
matty...
  • 605 posts
Posted 04 June 2015 - 09:20 AM
What are your concerns with it? What is the reason behind moving the carb off to side? I may be able to suggest an alternative design for you. Thanks
#73 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 04 June 2015 - 09:53 AM
Concerns were particles of fuel 'clinging'to the outside of the curve! Cylinders 3 and 4 getting a disproportionate share of the mixture.
I would like to move the carb mouth 'out of my face' making it easier on the ears, also run a mahoosif long 3D printed bellmouth for torque.
#74 matty...
matty...
  • 605 posts
Posted 04 June 2015 - 08:56 PM
I see, it would be difficult to predict whether it would effect the atomising or not without dynoing it. Having a rough texture inside the inlet will help prevent this, I have bead blasted the inside of some of the race manifolds I have done to help prevent this.
If you are wanting to increase the runner length for better low/ mid range then Vizard recommends increasing the runner length between the inlet and carb for better results, instead of using trumpets, may be worth considering?
Changing the entry angle of the trumpets also has an effect of how well the the pulse tuning works, so if you have access to a 3D printer it's worth trailing a few different ones out.
#75 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 04 June 2015 - 11:08 PM
Just looking at your site the Turbo Tecnics manifold with a twist might be the sort thing I'm speculating about.  I'll mull it over, cheers for the input.
