Mini Won't Start?
electrical
6 replies to this topic
#1 jbarney
jbarney
    Starting My Mini Up
  • 1 posts
Posted 30 January 2015 - 02:40 PM
Hi all, I have a 1984 mini mayfair and today she hasnt been starting. I drove to work alright but had to jump start her in the evening.
When I turn the ignition I get a "Clunk", which I assume is the starter motor engaging, but nothing turns over. I am hoping it is a dead battery because that would be an easy fix.
My only/main concern is that I have been driving around for the last few months with no issues. It is possible that leaving the heater on has drained the battery? (The switch was on but the heater wasnt running). I had an issues about 6 months ago which on the surface seemed the same, except it turned out that the starter motor bushes were worn so werent making a decent connection. These were then replaced and I have had no issues since. Any advice would be greatly appreciated, I am going to see if I can get her started now and see if I can charge the battery a bit. Cheers in advance.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 30 January 2015 - 03:50 PM
Test the battery and alternator voltages, sounds like one of them. have a look at Kernowcoopers thread on how to do it. http://www.theminifo...vehicle-earths/
#3 eilz1999
eilz1999
  • 68 posts
Posted 30 January 2015 - 11:04 PM
Check the earth leads, including the one in the engine compartment. Jump starting the car will usually determine battery fault.
#4 coopdog
coopdog
  • 4,506 posts
Posted 30 January 2015 - 11:34 PM
Yeah my battery would just die before I replaced it,
Sometimes it's just down to a cold snap and it would be flat
#5 Ado1379
Ado1379
  • 588 posts
Posted 31 January 2015 - 03:17 PM
check your fanbelt tension?
or you could run a multimeter across the battery terminals (if you manage to get it running)
#6 Mini Cheddars
Mini Cheddars
  • 1,209 posts
Posted 31 January 2015 - 03:32 PM
Clunk? Could be solenoid. Is yours on your starter motor or wing mounted?
#7 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 31 January 2015 - 03:41 PM
Cold weather destroys batteries in a very short time. Sounds like yours is on its way out. Get it jumped, take it for a long drive (15 miles or so) to charge it then try starting it again a few hours later. If its struggling then you'll need to get down to halfords to get another battery.
