Hi all, I have a 1984 mini mayfair and today she hasnt been starting. I drove to work alright but had to jump start her in the evening.
When I turn the ignition I get a "Clunk", which I assume is the starter motor engaging, but nothing turns over. I am hoping it is a dead battery because that would be an easy fix.
My only/main concern is that I have been driving around for the last few months with no issues. It is possible that leaving the heater on has drained the battery? (The switch was on but the heater wasnt running). I had an issues about 6 months ago which on the surface seemed the same, except it turned out that the starter motor bushes were worn so werent making a decent connection. These were then replaced and I have had no issues since. Any advice would be greatly appreciated, I am going to see if I can get her started now and see if I can charge the battery a bit. Cheers in advance.
