Kad Front Hubs Or Minisport Front Hubs?
brakes electrical
15 replies to this topic
#1 AdsMarshy27
AdsMarshy27
  • 25 posts
  • Local Club: BMC & Geeks 'n' Freaks
Posted 21 February 2015 - 08:07 AM
What hubs are better KAD or minisport? help!
#2 spaceframemini
spaceframemini
  • 383 posts
Posted 21 February 2015 - 08:12 AM
I run the kad hubs but minisport look better
#3 AdsMarshy27
AdsMarshy27
  • 25 posts
Posted 21 February 2015 - 08:13 AM
I don't mind about looks too much it's merely performance I'm after
#4 Earwax
Earwax
  • 488 posts
Posted 21 February 2015 - 10:30 AM
What makes a hub a performance item?   It s weight .. maybe..... a little......  but if you are planning to run heavy wheels it is a bit like trimming toenails to save weight
its ability to withstand bumps.... seems that the originals were pretty good at that
ball joints... now there is something to look into.. they both look to have the metro type which is a good thing, not sure if allowed in period type racing?
now even though you can't see them , they both look good but a bit pricey....imo  if you were to work out bang for performance buck, you would be better off using that money to get some sticky/track day tyres
#5 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 21 February 2015 - 11:14 AM
Alloy hubs are a great way of reducing unsprung mass, just like putting light weight wheels on the car. It will make the suspension work to its best as more energy will be transferred to the cones and shocks. Sticky tires are only useful if you have an effective and efficient suspension set up.
Edited by Steve220, 21 February 2015 - 11:16 AM.
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 21 February 2015 - 12:13 PM
Does anyone know how substantial the weight loss is?
#7 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 21 February 2015 - 03:56 PM
25% lighter according to KAD, 1kg lighter according to minisport
#8 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 21 February 2015 - 03:58 PM
the KAD ones as they are casting that has then been machined as apposed to minisports billet item
#9 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 21 February 2015 - 05:31 PM
I went for the Minisport hubs, and the quality is very nice indeed.  I went for these as there seemed to be a fair bit of bias towards the KAD ones, and their design from what i read online from various forums.
However if you do go for the Minisport ones i would run a tap through the helicoils before fitting the bolts, mine were very tight and ended up locking up one bolt which meant drilling it out and re-helicoiling it up.  So i tapped the rest and they all went fine.  And also keep an eye on the ball joints, as i got some very nasty looking ones, they probably worked fine but they had been attacked with a grinder.  I sent mine back for some better ones.
Andy
#10 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 21 February 2015 - 06:54 PM
so you went for the minisport ones despite the bias towards the KAD ones and then had issues with them?
#11 AdsMarshy27
AdsMarshy27
  • 25 posts
Posted 21 February 2015 - 08:12 PM
Thanks for all the advice guys helps a lot! The KAD ones are slightly heavier but the quality seems better so I think I'll go down the KAD route. Any objections let me know :)
#12 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 21 February 2015 - 08:40 PM
I have the KAD ones, they look like nice bits of kit to me.
Also... if I ever need to carry any spares (its going to be a track car)  these can be put on either side, bit useful there for a tight wallet like mine
#13 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 21 February 2015 - 09:02 PM
meant negative bias towards the kad ones!  Whats your point? That im an idiot?
The threads are out there on the kad ones if you do a search! The quality of the machining and material is great - i just had a slight issue with the fit of the helicoils, doesnt mean they are not good hubs - maybe i got the trainees hubs
Edited by AndyR, 21 February 2015 - 09:06 PM.
#14 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 21 February 2015 - 09:11 PM
not at all, I misunderstood what you meant, I thought you meant the reviews you read were positive towards the KAD ones
no offence meant
#15 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 22 February 2015 - 04:56 PM
give me a shout if you want a set. got some still boxed ones.
Also tagged with one or more of these keywords: brakes, electrical
