Main Beam/high Beam Rh Side
electrical
5 replies to this topic
#1 new 1995 owner
new 1995 owner
  • 18 posts
  • Local Club: hull mini owners club
Posted 23 February 2015 - 08:03 AM
My RH side main beam has stopped working, iv changed the bulb so that's not the problem, tested with a multi miter no current going to it, is there a fuse or a relay that could be to fault, many thanks in advance.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 23 February 2015 - 08:20 AM
No, but plenty of dodgy wiring... first check the bullet connectors behind the slam panel ( front panel by the bonnet latch )
#3 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 23 February 2015 - 10:25 AM
John is correct the connectors behind the slam panel are usually the problem, but some models, not sure about yours have 4 inline fuse holders behind the dash just above the steering column bracket that fuse the LH main beam and Dipped beam and the RH main and dipped beam if all else fails it's worth a check.
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 23 February 2015 - 01:38 PM
nods
#5 splintercat
splintercat
  • 616 posts
Posted 23 February 2015 - 02:26 PM
just had the same problem mate but it was my lighting switch itself that caused the problem......
#6 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 23 February 2015 - 03:22 PM
Yup we had a fault where the glass(inline) fuse holder had melted slightly. Changed these to blade fuses which solved the issues
