I am wanting a bump stop that will stop my swing arms at 40mm from my reinforment point.
Thoughts?
Oh I am looking at the Minispares redesigned ones..
Front Bump Stops. How Tall Are They And How Much Do They Squash?
, Mar 08 2015 06:48 PM
suspension
5 replies to this topic
Posted 08 March 2015 - 06:48 PM
Posted 08 March 2015 - 08:20 PM
You can always fit a spacer between the Bump Stop and it's Mounting Point.
Have you made a measurement of the total height for the Bump Stop you need?
Posted 08 March 2015 - 08:38 PM
I need to fill 40mm.
So yes spacers and a bump stop but must stop at 40mm or 45mm but that can be adjusted.
Posted 30 March 2015 - 10:13 PM
The new Minispares ones arrived today. 36mm. Shound be fine just position further up the arm.
Posted 31 March 2015 - 07:45 AM
Sportspack cars have a chunky spacer under the front bump stop, a pair of those will fill the gap enough including some squashing I would think.
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
