Spi Cutting Out When Warm
36 replies to this topic
#16 minisprite1275
minisprite1275
    Starting My Mini Up
  • 1 posts
Posted 22 April 2015 - 04:42 PM
hi all
proberly a silly question but can you just bolt on a new stepper motor ?
im having trouble with my spi (1994) when the car is warm it some times cuts out at junctions.
when driving it seems like its missing at times,when on or near full throttle
any help would be most welcolm
#17 FlyingScot
FlyingScot
  • 2,676 posts
Posted 23 April 2015 - 08:39 AM
hi all
Better to start your own thread, there are many reasons for the symptoms.
FS
#18 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 24 April 2015 - 08:26 PM
Well, the code reader arrived. Connected it up and there where 2 stored faults. 02 inlet air temp sensor circuit fault and 16 throttle pot circuit fault. I cleared these and they didn't come back, I've been driving the car for 2 days and it seemed to be ok, felt really smooth and was idling fine.
Took the car for MOT this morning and it drove there nice, I left it with them as I'd got other stuff to be getting on with, when I went to collect it they informed me it had failed the test on emissions and it was cutting out and very jerky. It was virtually undriveable on the way home, I had to keep the revs up to stop it from stalling and it's now got a massive flat spot when you go to pull away.
Tried the code reader and it's showing no faults and all the live data seems to show good data that everything is working fine.
#19 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 April 2015 - 08:34 PM
what do you mean by good data? what are the figures.
#20 MR J
MR J
  • 416 posts
Posted 24 April 2015 - 08:59 PM
Water temp 75
Inlet air temp 44
Map 023kpa (running) 100kpa stood
O2 between 0 and 1.8
Not too sure if the O2 is fluctuating too much.
#21 MR J
MR J
  • 416 posts
Posted 24 April 2015 - 09:02 PM
https://youtu.be/zo6bp1gB5bQ
This is the live lambda data.
#22 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 April 2015 - 09:19 PM
44 air temp seems high.
#23 MR J
MR J
  • 416 posts
Posted 24 April 2015 - 09:22 PM
I'd have thought that was quite normal for an under bonnet air temp?
#24 MR J
MR J
  • 416 posts
Posted 25 April 2015 - 09:01 AM
Now not so sure on the stepper motor issue, it seems to be operating fine throughout it's range when hot and cold.
New ignition parts ordered and also a new lambda sensor, going to also strip and clean the throttle body over the next few days.
#25 FlyingScot
FlyingScot
  • 2,676 posts
Posted 26 April 2015 - 02:05 PM
Seems high to me too and by way of comparison....
ECT 80
MAP 28
RPM 850
IAT 24
It quite cool here today at around 7.5c but with my Spi warmed up and standard air box the inlet air is just 24C.
Are you running a K&N cone by any chance ? As otherwise the IAT seems too high to me.
FS
Edited by FlyingScot, 26 April 2015 - 02:05 PM.
#26 FlyingScot
FlyingScot
  • 2,676 posts
Posted 26 April 2015 - 02:09 PM
What the condition of the coil? Just a thought when I re read your symptoms.
I had a Sidewalk that had intermittent cut outs and then running like a pig, turned out the coil was on its way out and it showed itself only when hot.
There's a pinned FAQ about ignition coils (also checked somebody hasn't fitted the wrong one meant for older minis)
FS
#27 MR J
MR J
  • 416 posts
Posted 26 April 2015 - 04:13 PM
Yes, its got a K&N cone filter filtted.
I'll test the inlet air temp again when its cold. I fitted a new coil about 3 years ago but i suppose it could be failing.
What are your thoughts on the live lambda data? Should it be switching as far as 0.0v and 1.8v?
Edited by MR J, 26 April 2015 - 04:19 PM.
#28 MR J
MR J
  • 416 posts
Posted 26 April 2015 - 06:58 PM
Just checkedon the live data for the IAT, it's reading ambient at 12 deg cold.
#29 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 27 April 2015 - 09:09 AM
check your coil, as FS mentioned above
#30 FlyingScot
FlyingScot
  • 2,676 posts
Posted 27 April 2015 - 10:49 AM
Okay seems the IAT could be right, lambda looks okay, I'm less and less convinced of the absolute number as long as it's moving quickly up and down.
Check it's the right coil too, I have see cars with the wrong one fitted which subsequently failed.
KernowCooper has a guide here http://www.theminifo...tributor-types/
FS
