Indicator & Hazard Light Problem
Best Answer KernowCooper , 07 May 2015 - 05:32 PM
Still points to a dirty connection, or a flat battery. You say the battery is charged, so have you checked the fuses on the fusebox and the related wiring, when you put a load on a circuit and the voltage drops off it points to a dirty connection
Go to the full post
21 replies to this topic
#16 monkeymonk
monkeymonk
  • 367 posts
Posted 04 May 2015 - 07:55 PM
Bank Holiday Bump!
#17 monkeymonk
monkeymonk
  • 367 posts
Posted 05 May 2015 - 05:21 PM
Update.....
I have 0v going into the indicator stalk but 12v coming out the flasher unit.
There is also 12v at the red/green wire and white/green wire constantly.
I also have continuity between the red/green and the white/green.
Any ideas?
#18 monkeymonk
monkeymonk
  • 367 posts
Posted 06 May 2015 - 05:18 PM
I give up!
Time to get the local auto electrician out
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 May 2015 - 07:07 PM
You say you have 0v going into the stalk can you back track the wire and test it where it goes into the hazard switch and then back to the flasher unit
#20 monkeymonk
monkeymonk
  • 367 posts
Posted 07 May 2015 - 08:55 AM
There was 12v at the hazard switch and 12v at the flasher unit.
When i tested the voltage going into the flasher unit (purple and orange wire) i was at 12v but when i turned the hazards on, the voltage dropped to 1.5/2v
#21 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 May 2015 - 05:32 PM   Best Answer
#22 monkeymonk
monkeymonk
  • 367 posts
Posted 12 May 2015 - 05:08 PM
Problem finally solved!!!
Re-crimped various connections, put in new in-line fuses and i now have indicators and hazards!
Many thanks all
