Hif44 Throttle Assembly Problem
engine
3 replies to this topic
#1 olliewiltshire
olliewiltshire
  • 41 posts
  • Local Club: Mini Life
Posted 13 April 2015 - 08:46 AM
Hello guys, i was looking over my car at the weekend and discovered that when i depress the throttle pedal all the way to the ground that it doesn't actually open the throttle on the carb all the way open. it stops about half a cm away from the stopper on the carb. I did check if there was any slack in the cable that could be causing this but it was tight already and i know that the cable hasn't stretched as it was a new cable last month.
is this normal or has anyone else had this problem before?
any one that can shine some light on this situation it will be greatly appreciated :)
my set up is
mg metro 1300
ballanced crank
286 kent cam
turbo oil pump
hif 44 carb
city e diff
cooper spi stage 4 head
Dual timing chain
Metro clutch
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 13 April 2015 - 08:51 AM
First off, does your carb have the correct throttle assembly as I've seen minis plodding about with the wrong type of arm?
Had this problem last week on a friends car. Our fix was to bend the throttle pedal up to provide more travel. I assume your pedal is reaching the carpet which is preventing full travel? It's also worth checking that you don't have a load of carpet underneath the pedal.
Edited by Stiggytoo, 13 April 2015 - 08:53 AM.
#3 olliewiltshire
olliewiltshire
  • 41 posts
Posted 13 April 2015 - 09:10 AM
thanks for the quick reply, i have check the assembly and it is correct.
oh really, i have have to check under the carpet tonight as you are right its just reaching the carpet and its preventing it going any further
#4 Ethel
  • 26,074 posts
Posted 13 April 2015 - 07:08 PM
Thw metro throttle is the one with the snail cam & cable guide, the cable also has the plastic end that slides into a slot. An alternative to bending would be to add some packing under the pivot bracket for the pedal. Also have a look at how worn it is.
