Hi, I'm new to the forum but old to minis.
Been 20 years+ since I owned my last one (Mini Advantage) but recently back in a saddle when I bought a 1996 J-spec Cooper SPi on a whim.
I've not had a lot of time to pick over my new purchase but the most immediate and pressing issue is that I'm trying to sort out something that I've never encountered before. I've scoured the forums and didn't find exactly this issue...
Basically on hard right hand cornering (roundabouts etc) the nearside rear wheel will rub (loudly) on the vertical edge of the wheel arch, it leaves polished-steel grooves at the lower back of the arch (rear). So I don't do hard right turns at the moment. There's no other hint of an issue, no steering wander, straight line issues, just the cornering and noise.
If stick my hand behind the wheel and compare the rear tyres, on the nearside there's next to no gap between the tyre wall and the arch, on the driver side rear there's 5-10mm gap, which means the near side isn't right.
My thought was initially that someone had missed off the wheel spacer or it was wheel bearing/radius arm/suspension. I've taken wheels off and compared side and yes it appears that somehow the nearside radius arm/hub setup is over towards the body more. The shock is tight to the body. There is no spacer but the brake hubs look to be spacer types anyway, both the same.
Can a radius arm be bent? or it more likely to be sub frame rot issue that making it out of alignment? camber setting maybe? all of the above? The sub frame as far as I've inspected looks pretty good so I'd be surprised if it were that but the radius arm fixing is in the depth of it...
I've posted a picture of the offending side and non-offending, I'm guessing they wont be a lot of use other than to show the mini isn't in original spec (Cones have been replaced by springs etc.) but you never know. Happy to take more if it helps
Just after thoughts / hints as to what I might aim to look at so I can narrow down the fix. Thanks.
