Msa Mandate - Fhr Devices Will Be A Mandatory Part Of Safety Equipment For 2016
22 replies to this topic
#16 The Elfman
The Elfman
  • 25 posts
Posted 24 June 2015 - 03:30 PM
Notching tool ? posh devil I use a pen and grinder...lol  Good luck I can see what you mean with your tube angles.
#17 nicklouse
  • 18,696 posts
Posted 24 June 2015 - 04:13 PM
Got one with the cage as it came IKEA style.
I know who I left it with 20 some years ago..........
#18 beakerthemuppet2
beakerthemuppet2
  • 39 posts
Posted 25 June 2015 - 12:43 PM
hmm theres only like 4 manufacturers of FHR devices.... bet they are chuffed to bits.
still it is all a bit short notice.
#19 The Elfman
The Elfman
  • 25 posts
Posted 27 June 2015 - 08:26 AM
I wish I got one now, but as I am probably well over half way I will carry on as I am..
It will be interesting to see the different way people solve the problem.
#20 nicklouse
  • 18,696 posts
Posted 27 June 2015 - 02:34 PM
Now here is a thought.
I am not too sure what size tube to use.
38 or 40 or 42mm
38 will be strong enough but not the same size as the other tubes.
Better drop a mail to Rollcenters.
#21 The Elfman
The Elfman
  • 25 posts
Posted 27 June 2015 - 07:46 PM
38 X 2.6mm or 40 x 2mm if you can find it...
#22 nicklouse
  • 18,696 posts
Posted 27 June 2015 - 07:49 PM
Roll centres do it so getting it ain't an issue? But is there a requirement such as should it be the same size as the exisiting tubes? Or is it free? Which I don't belive as you will get some fool using some welded tube that is too small.....
Opps missed it
1.3.9. Harness Bars. Minimum dimensions 38mm x 2.5mm or 40mm x 2.0mm. Cold Drawn Seamless Carbon Steel with minimum tensile strength of 350N/mm2. Harness straps may be attached by looping around the tube or by threaded fixings using inserts as drawing No. 44 welded into the tubes(s).
Edited by nicklouse, 27 June 2015 - 07:54 PM.
#23 The Elfman
The Elfman
  • 25 posts
Posted 28 June 2015 - 12:41 PM
I am using a mixture of tube sizes all over my space frame, they are all legal..
