My 7 Port Head
117 replies to this topic
#106 minipete
minipete
  • 458 posts
  • Local Club: East Yorkshire MOC.
Posted 19 September 2015 - 08:30 PM
Oh thats a bugger.
#107 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 20 September 2015 - 01:57 AM
looks absolutely lovely especially with the webbers but if your stuck for a garage you could always build a bottom end in your house/bedroom
when my sister moved out I wanted to convert my her bedroom into an engine building workshop but unfortunately was vetoed on that pretty quickly, had a dishwasher, tools and everything ready to move in aswell :(
#108 R.S.P
R.S.P
  • 501 posts
Posted 20 September 2015 - 10:33 AM
Sorry managed to post in wrong thread  :ohno:
Should not let us oldies loose with a computer
Edited by R.S.P, 20 September 2015 - 10:38 AM.
#109 R.S.P
R.S.P
  • 501 posts
Posted 20 September 2015 - 10:53 AM
Dont give up mine is a long way out of tune running out of fuel at about 4800rpm and I run a SW10 cam so doesn't come on cam until 3400rpm I still managed to keep up with a freshly built 1380 by a reputable mini tuner, the torque of this engine seems a massive jump from my mpi
Save up some cash and build a good bottom end they don't take up much space
Edited by R.S.P, 20 September 2015 - 10:55 AM.
#110 severn
severn
    Starting My Mini Up
  • 1 posts
Posted 19 October 2015 - 01:12 AM
hi,just-finished-building-1293-in-a-cooper-S,-10.3-1-compression,mild-cam,1.25-roller-rockers,7port-alloy-head-with-20cc-chambers,decent-crank-and-rods,full-ARP-hardware-and-studs,-Maniflow-LCB,-2x40dcoe-webers,decent-distributor,-could-anyone-give-me-jetting-and-timming-suggestions-for-this-engine,cam-set-at-108,any-help-greatly-appreciated,will-post-pics-if-Ican-figure-it-out,Thanks-everyone,Neville-in-New-York
#111 mk1leg
mk1leg
  • 9,343 posts
Posted 19 October 2015 - 10:27 PM
The problem for me is that my workshop, garage etc is a strip of tarmac by my front door. If I had otherwise the head would most definitely gone onto a tweaked bottom end. As for paying someone else to do the same there`s no-one within miles who would know what they are looking at even, It`s all curry and pizza round here  :X
Hi..Hazel do not give up I stripped my engine on a bit of carpet on the gravel drive.........its the rebuild you realy need a bench....lol
Edited by mk1leg, 19 October 2015 - 10:27 PM.
#112 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 20 October 2015 - 05:57 PM
Too late, the head and carbs have gone, the 1275 is sat on a pallet yielding the odd bit and there is a tweaked 1380 sitting in the hole now just waiting for the 27th so`s I can get his carb and some other bits and then...............................Clubby lives!!! :P
#113 mk1leg
mk1leg
  • 9,343 posts
Posted 20 October 2015 - 06:02 PM
sorry to hear you have had problems..........Touch wood Mine is still going fine........what head are you using and what cam is in the 1380.......and whats the carb your using
#114 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
Posted 21 October 2015 - 05:57 PM
Bloody `ell, lol. It`s an A+ engine with all parts reground so just like new basically. I think the valves are bigger than standard but I won`t swear to that. The cam is a Piper 266 with high lift rocker shaft from MiniSport (boy do those springs close up!) The carb, when it arrives at Minispares on the 27th, will be a HIF44 which everybody including the engine builder has recommended. I have fitted a stainless LCB and am waiting for the stainless connecting pipe to arrive so`s I can fit my lovely stainless twin pipe RC40 box. Flywheel is lightened steel, flat-top Powermax or better pistons, vernier timing set up, powerspark dizzy, Viper coil, NGK plugs and that`s about the lot I think. Roll on the 27th, I`m getting quite orgasmic in anticipation. OH!yea, it`s got a beefed up gearbox, central oil pick-up, straight cut transfer gears and a  cross pin diff giving a 3.1:1 final drive.  :P
#115 mk1leg
mk1leg
  • 9,343 posts
Posted 21 October 2015 - 10:30 PM
Try a BCE needle or BBC
#116 mk1leg
mk1leg
  • 9,343 posts
Posted 21 February 2016 - 06:54 PM
a short vid of a run on last meet
#117 coopdog
coopdog
  • 4,506 posts
Posted 21 February 2016 - 07:05 PM
What power is that putting out?
#118 mk1leg
mk1leg
  • 9,343 posts
Posted 22 February 2016 - 08:44 PM
Hi..some where around the 115-120......not had it R/R yet will Try and get to the UK later this year at SRE......
Vintage Mini's Boss recons with my spec
