Acid Dip
suspension
Best Answer Guess-Works.com , 24 July 2015 - 06:38 PM
Better off using a decarb dip and blast them... Go to the full post
2 replies to this topic
#1 1963MKI
1963MKI
  • 163 posts
Posted 23 July 2015 - 06:01 PM
Thinking of dipping my hubs in acid to clean rust of them. I have taken the bearings out but not the inner races ? will the acid damage the inner race ? I use a phophoric acid based rust cleaner.
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 23 July 2015 - 07:16 PM
Yes, the acid can etch the surfaces of the bearing races.  Remove them before you proceed.
You will also need to thoroughly degrease the hub before you think about washing them with the acid.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 July 2015 - 06:38 PM   Best Answer
Also tagged with one or more of these keywords: suspension
