#16
Posted 06 August 2015 - 02:26 PM
#17
Posted 06 August 2015 - 05:01 PM
I did one for mine with a CO meter onboard and tweaked mine over a week, well worth spending the time to get it right
#18
Posted 07 August 2015 - 04:45 PM
AC,
Could you help me understand why I would need a custom needle? There are hundreds of stage 1 HS4 998cc running either AAU or AAA, what's so special about my engine? Wear?
#19
Posted 07 August 2015 - 04:47 PM
AC
Edited by ACDodd, 07 August 2015 - 04:50 PM.
#20
Posted 07 August 2015 - 06:55 PM
Alex, to see the difference between AAU and AAA needles use this link : http://www.mintylamb.co.uk/suneedle/
Would recommend you getting a new red spring for the dashpot. I've had similar issues with weak spot on twin HS2s and keeping the same needle but going from blue to red springs sorted this. In your case yellow spring would be way too heavy, that's why I would suggest a new red spring - the one I got about year back from Mnispares was usefully stronger and managed to cure a flat spot on my 998.
And if you really want to try a different needle then the ADL may richen up the mid-range very slightly compared to AAU
#21
Posted 15 August 2015 - 12:11 PM
All right, thanks for all your answers, I'll look into it.
Mini Technical Sections →
Problems, Questions and Technical →
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
