Mini Mayfair Radio: Philips R570
electrical
Best Answer ace01 , 07 August 2015 - 04:03 PM
It does require the use of some special kit and software, sorry I should have explained that. I have the kit here and can do it if you wish.  But let the unit timeout first and check that you have the correct code.
Go to the full post
5 replies to this topic
#1 TonyAlonG
TonyAlonG
    Just On Tickover
  • 8 posts
Posted 07 August 2015 - 07:13 AM
Hello,
I have a Mini Mayfair 1991 and I have a very frustrating problem with the radio which is a Philips R570.
I know the code for it, but unfortunately I accidentally inserted it wrong. Now the display only shows "CODE" and won't let me re-insert it because it has frozen.
Does anyone know how I can fix the "CODE" problem and get my radio working?
Thank you,
Anthony Alongi
#2 phil hill
phil hill
  • 616 posts
Posted 07 August 2015 - 09:32 AM
From memory I *think* the time period between failed attempts increases each time you incorrectly enter the code.  So if you leave the radio powered up for a while you should be able to have another go at entering the code.
Failing that there are services which can recover the codes for a modest sum advertised on Ebay, Rover Owners club etc.
Phil.
#3 ace01
ace01
  • 457 posts
Posted 07 August 2015 - 10:06 AM
As above.  However, be aware that if you enter the code incorrectly more than ten times the radio will be locked forever. If the code does not work the next time you put it in, then the correct code can be found.
As an aside it is possible to manually change these codes.  I have done a few, so don't automatically assume that the code on the card has to be correct.
#4 TonyAlonG
TonyAlonG
    Just On Tickover
  • 8 posts
Posted 07 August 2015 - 12:06 PM
Could you kindly explain to me how the codes can be changed manually?
#5 ace01
ace01
  • 457 posts
Posted 07 August 2015 - 04:03 PM   Best Answer
#6 TonyAlonG
TonyAlonG
    Just On Tickover
  • 8 posts
Posted 08 August 2015 - 05:47 PM
I have followed the unit timeout method and inserted the code, it works perfectly bow, thank you for helping me out.
