So just rebuild my 998 and got around 250 miles. Within those miles i have noticed that the engine runs far better than before in every way (Up to 4000rpm due to running in there is more power especially low revs say 1500 - 3000 rpm the car just seems to take off quicker, revs climb faster, also much better throttle response i always had like a 1-2 sec delay where as now it more or less instant, no noticeable flat spots between 1000 - 4000 rpm. Note this i only according to the Butt dyno
Now the problem, Any gear, under acceleration half throttle or more there is a knocking noise that starts around 2800 rpm, then goes away around 3000 rpm. Its not pinking because i heard that when adjusting ignition timing and got that to go away after retarding the dizzy. Only tuned by my self adjusting on feel and the colour of the spark plugs. I do want to get is rolling road tune but i want to get some miles on the engine and probably switch to an Aldon yellow dizzy for the more suitable advance curve.
I am going to look into this further checking things around the engine not necessarily the engines internals could be manifold knocking on something but it does sound internal, bit like the knock/rattle on diesel engines.
Also going to check compression because i want to compare the results anyway to how then engine was before the rebuild
Info about engine is in my signature also im running 99 Octane fuel and the 12g202 head had 40 thou skimmed off and some light modification the the combustion chambers and ports according the "yellow engine bible".
I might also be able to get an audio file uploaded later depending if my phone picks the sound up.
Just thought i would make a topic so anyone with ideas can suggest them.
Edited by Ginge620, 18 August 2015 - 12:37 AM.
