Hi everyone,
So I fitted D1 replica wheels with 165 tyres on my mini that has standard drum brakes and normal length studs. When I took it for a drive I heard a funny sound. Turns out the tyre was rubbing against the plastic cover on the rear shock.
So I tried fitting a 5 mm spacer and that resulted in very little thread remaining on the stud, which didn't feel like something safe.
So I was wondering if I should fit longer studs and then add the 5 mm spacer to solve the issue. I was also wondering if it would be advisable to fit similar spacers in the front? Lastly would spacered drums be an option if I want to keep the car archless.
Regards,
Vinay
