Suspension Setup For Road Use
suspension
3 replies to this topic
#1 Dave27
Dave27
    Just On Tickover
  • 7 posts
Posted 08 October 2015 - 12:50 PM
Hi all,
I'm returning to mini's after a few years off, does anyone have any advice for suspension set-up for road use I have a mk1 cooper which has been converted to standard dry suspension on 10" wheels.
I kept these suspension parts which are in still in good condition and usable.
Hilos
adjustable rear camber brackets
adjustable front tie bars
adjustable bottom arms
I will be purchasing new adjustable shocks and knuckle joints I used spax in the past but from memory they were quite harsh even on the lowest setting, I'm in favour of lowered GAZ ones this time or an alternative ? are they any good ?
Also does anyone have settings for suspension for front and rear
ride height
camber
castor
toe
Cheers Dave
#2 racingbob
racingbob
  • 3,061 posts
Posted 08 October 2015 - 01:02 PM
well to answer your question mine set up for fast road and very happy with it
I have protech shocks, 1.5 camber 3-4 castor and 1 - 2m toe out
rear just got about .25 camber
its lowered with hi los with touch taken off the rubber bump stops
and can slide the front of my finger in the gap
I have new genuine rubber cones on the front
you may want to leave the bump stops as is but make sure about 12mm gap
I use mine for B roads around near me its a fun car, not my main car
#3 Broomer
Broomer
  • 1,771 posts
Posted 08 October 2015 - 04:01 PM
I run mine at 200mm sills to floor, with -1.5 camber on the front with 5.5 degrees of castor as close to parallel as possible / a touch of toe out.
Rears are set -0.5 degrees of camber and some toe in.
Seems Ok but I feel the 10x7 wheels have hampered the handling.
#4 Dave27
Dave27
    Just On Tickover
  • 7 posts
Posted 09 October 2015 - 08:08 PM
Thanks for the advice will be very useful.
Also tagged with one or more of these keywords: suspension
