High Build Primer (The Yellow Spray Can Stuff)
20 replies to this topic
#16 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 14 October 2015 - 10:07 PM
To be honest as you are at this stage I would strip it all off and start again. Paint reaction is a pain and very frustrating to contend with and can be bloody expensive as well. Been down this route with my lads car.
#17 Chris1992
Chris1992
  • 2,022 posts
Posted 15 October 2015 - 12:09 PM
ok thanks guys. I think what ill do is take off a door and test it on that. if it sprays over fine then all is well, but if not then ill strip the car back
#18 Chris1992
Chris1992
  • 2,022 posts
Posted 16 October 2015 - 02:29 PM
who the hell is this joker??? admin!
#19 kezzkitkat
kezzkitkat
  • 714 posts
Posted 16 October 2015 - 10:11 PM
or just bar coat what you have got just to be certain i tend to stay away anything thats 1k thats so called build is next to none and i find rarther expensive in cases than a 7.5 lt kit of 2k high build if the facilities are not suistanble to spray you could roller it on. its abit more work to sand
#20 Cooperman
  • 23,350 posts
Posted 17 October 2015 - 09:49 AM
I would finally surface with yellow spray putty, either 2k of celly, then flat and spray a 'witness coat' of black to confirm the surface is correct to profile when you lightly sand this down. Then finally prime with a grey primer before top coating and then knib back lightly and spray the top coat.
If in doubt, PM Ben-O on here as he is a top man regarding painting.
#21 midridge2
midridge2
  • 1,794 posts
Posted 17 October 2015 - 10:44 AM
Be very careful in using various stoppers/primer coat. witness coats as you will risk the chance of a reaction unless you use compatable  paints etc.
