New To Spi Engines. Help
Best Answer FlyingScot , 07 February 2016 - 08:59 AM
UPDATE. I found a small split in the pipe which connects inlet manifold to fuel trap. Replaced that and it's running perfectly. I will give it a good long run now and warm everything up and see how we go.
I have also replaced my alloys with the orignal steel wheels and wheel trims that where found on the 1995 sidewalk. It's now as oringal as it left the factory.
Thanks everyone. I will get pictures up soon
The 3rd answer to your original question....
FS Go to the full postlots of pipes to the air filter check them all for splts
there is also a Little black box to the left of the spi unit on the bulkhead if i remember correctly with 2 pipes to it check them for splits
#16
Posted 25 January 2016 - 10:29 PM
#17
Posted 26 January 2016 - 06:02 AM
#18
Posted 03 February 2016 - 08:21 AM
I have tired to adjust the throttle link which I found at the back of the carb (little 7mm nut on a small screw that turns and pushes against the pin for the stepper motor.
#19
Posted 03 February 2016 - 10:22 AM
It cannot be done by pressing the throttle 10 times unless you have an early SPi system with the throttle switch.
FS
#20
Posted 03 February 2016 - 10:30 AM
You have to work logically through the information on the pinned threads. Diving into "I've had a smiliar problem and it was.." wont help.
The system tries at all cost to keep the car running despite sensor failures misadjustments etc but relies on the fact that your then local Rover dealer would plug it into Testbook at service time or when you found an issue and determine what was amiss.
If you don't have diagnostic gear and can't buy or borrow some you need to go through each step carefully.
Most problems on SPi cars are due to lack of maintenance (vacuum pipes, sensors etc) and deterioration (wiring, lambda, stepper motor coils relay packs etc).
Have a look through the the pinned threads and also the one on having a code reader and look to see if there is someone local to you who could help.
FS
#21
Posted 03 February 2016 - 12:15 PM
For all your general Mini chat. Please don't ask any technical questions here"
Moved to correct section
FS
#22
Posted 03 February 2016 - 05:21 PM
I appreciate all the advice, still learning my way round the spi and apologise if I've repeated questions or annoyed people by using the wrong sections
#23
Posted 03 February 2016 - 09:28 PM
It's where all we fuel injection nerds hang out Or maybe that's just me...
Any case you will find folks happy to help
FS
Edited by FlyingScot, 03 February 2016 - 09:29 PM.
#24
Posted 05 February 2016 - 01:15 AM
FS
Its not just you....
#25
Posted 05 February 2016 - 06:10 PM
Definitely not just you or you...
I am just trying to learn and contribute as best I can...
I don't have a lot of direct experience with SPi, though I have helped sort a few.
Terry
#26
Posted 07 February 2016 - 12:52 AM
#27
Posted 07 February 2016 - 08:59 AM Best Answer
FSlots of pipes to the air filter check them all for splts
Edited by FlyingScot, 07 February 2016 - 09:00 AM.
