Best Oil
56 replies to this topic
#1 fenghuang
fenghuang
  • 796 posts
Posted 03 November 2015 - 10:56 AM
Doubtless this has been debated before, and I suspect both friendships and legs have been broken in the process, so sorry, but ...
Best oil for a road car?
Halfords do stuff branded as 20w50 for classics, and IIRC synthetic is a bad idea. Minispares do Castrol (in a pretty tin, which doubtless helps) and Unipart.
But any preference amongst the cognoscenti?
#2 nicklouse
  • 18,769 posts
Posted 03 November 2015 - 10:58 AM
Valvoline VR1.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,096 posts
  • Name: Neil
Posted 03 November 2015 - 11:02 AM
Yes this has been mentioned on numerous occasions. Do a search via Google with TMF in the search request and you will find your answer.
#4 jaydee
jaydee
  • 8,565 posts
Posted 03 November 2015 - 11:04 AM
As above, VR1 if you want a 20w50
Apart from the base oil quality, these engines need a lot of ZDDP, most of the cheap oils only have 700-800 ppm where VR1 has around 1500..much safer.
#5 Corey96Williams
Corey96Williams
  • 316 posts
Posted 03 November 2015 - 11:05 AM
I buy the Halfords brand, only because it's cheap and it has a photo Mini on the front of the tin  :D
#6 Wim Fournier
Wim Fournier
  • 177 posts
Posted 03 November 2015 - 11:11 AM
It is not so much the question how good the oil is you use, but how bad the blow by is in the engine of your car.
In the burning process for the working stroke waterdamp is formed and coal.
Most of that get rid via the exhaust. But, between the cilinderwall and the piston there is 'blow by' that pollutes the engine oil.
So often an oil change will do better for the sanity of the engine than an expensive oil.
Use the money you spend for a frequent oil change rather than the best oil.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 November 2015 - 12:11 PM
As above, regular servicing is more important than brand of oil...
#8 fenghuang
fenghuang
  • 796 posts
Posted 03 November 2015 - 12:24 PM
I had actually done a search, but found nothing recent, and the opinions of only a couple of currently active forum members who I will listen to without feeling any need to research further. (No names, but I'm sure they know who they are!)
Appologies for any irritation. Perhaps I should have posted the question in the No Question Too Stupid thread. ;-)
#9 Wim Fournier
Wim Fournier
  • 177 posts
Posted 03 November 2015 - 01:22 PM
I was'nt irritated at all. Just gave my opinion. We don't use our Mini's twenty thousand miles a year. So refreshing the engine oil every year will be enough. With 800 miles on the clock the oil will be only a bit discolored. Only because of the acid and water and coal that came in the oil by the burning proces, you can better get rid off before the winterstop. So Halfords or the sort will be all right.
#10 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 03 November 2015 - 01:33 PM
Just to add to the debate Practical Classic Magazine recommended Millers they do a special oil for the Classic Mini with an extreme pressure additive to help with the gearbox aspect of the oils work.
#11 fenghuang
fenghuang
  • 796 posts
Posted 03 November 2015 - 02:46 PM
... a special oil for the Classic Mini with an extreme pressure additive to help with the gearbox aspect of the oils work.
you mean to plug the leaks? ;-)
#12 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 03 November 2015 - 05:15 PM
I followed the advice of Calver and changed to MILLERS Classic Mini Oil 20W50. All the additives needed are in the oil.
You can use of course other 20W50 oils but then it was recommended to havbe additives. See Clavers site
http://www.calverst.com/
I am very happy with Millers for at least the last 4 oil changes.
#13 Dusky
Dusky
  • 5,322 posts
Posted 03 November 2015 - 05:39 PM
Vr1 is what I use in both the normal and the beast mini. Doubt a standard engine benefits from vr1, but on a 9k revving engine it made quite a difference in Hot oil performance.
#14 fenghuang
fenghuang
  • 796 posts
Posted 03 November 2015 - 07:10 PM
He makes a very convincing argument for using Torco 0W20. Was there a reason why you went for Millers instead?
#15 Cooperman
  • 23,369 posts
Posted 03 November 2015 - 07:23 PM
That very thin oil is not something I would personally ever use. What is the ZDDP figure for this oil as that is what the Mini requires because of its shared engine & gearbox oil.
I use Valvoline VR1, but the very, very best oil for a Mini is Kendall 20w50, although it is now hard to fine and very expensive. VR1 is readily available for a sensible price.
In the end you get what you pay for.
