Hello all, I'm having issue's with new bearings I fitted to the upper arms, the old were removed with no problems but now new are fitted the pins won't go through.... Any advice to what I may have done wrong ??
Posted 11 November 2015 - 05:04 PM
Posted 11 November 2015 - 05:07 PM
how are you putting the bearings in sometimes you compress the cage as you fit them and then the pin wont go in
Posted 11 November 2015 - 05:49 PM
I used a press to fit new bearings, If that is what I have done is there a way to rectify it ?
Posted 11 November 2015 - 06:50 PM
The Needle Rollers are un-caged (or they should be!!) and so they can skew off from straight, and this reduces the diameter inside, even the slightest bit off is enough. Just use a small CLEAN screwdriver or O Ring Pick to straighten them up.
If the Needle Rollers are caged type, take them out - they are the wrong bearing (Idler Gear Bearings).
Posted 11 November 2015 - 07:45 PM
The ones i removed were the caged type so i assumed thats what i needed to replace them with.
Posted 16 November 2015 - 08:56 PM
After a bit of research i have come to realise i don't have caged bearings after all !!! Still struggling to work out how to fit new bearings without crushing the casing.....
Any tips ?
Posted 16 November 2015 - 09:10 PM
Posted 16 November 2015 - 10:18 PM
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
