lambda readings
Posted 14 August 2006 - 03:27 PM
could there be an air leak? (i have tried nearly everywhere but to no avail)
could the sensor be duffed up?
could the sensor be clogged?
when unplugging the sensor it reads 0.8 - the ecu standard table entry, so he wasnt under the impression the sensor could be broken (anyone think differently?)
if anyone could suggest any reason or had any experience can they please lend a word of advice. thanks, kris
Posted 14 August 2006 - 06:23 PM
what colour are the plugs?
when was the Lambda sensor changed?
Posted 15 August 2006 - 04:18 PM
thank you,
Posted 15 August 2006 - 04:56 PM
Edited by Mini Sprocket, 15 August 2006 - 05:24 PM.
Posted 15 August 2006 - 05:23 PM
Have a read of this too http://www.theminifo...showtopic=20533
Have a diagnostic check carried out.
When engine is up to running temperature, coolant temp is roughly 90 degrees, air temp is air temp +5degrees ish or equal to, stepper possition is 30 +- 5, ignition advance is 15 degrees fluctuates a little but not by alot, throttle position should be 0.4 +- 0.1 volts, lambda should fluctuate through 250 and 550 milivolts at a rate of aproximately once a second Map should be at least 500 millibar
Posted 16 August 2006 - 08:11 AM
i have read those topics through many of times over and over!!!
it looks more and more likely to be coolant temp as ive had alot of people mention that. today i have someone coming to fit his super mighty minis championship winning injection setup to try and resolve the issues!
thanks alot!!!
Posted 16 August 2006 - 01:07 PM
only thing we can change now is loom and ecu. oh and actually the air temp sender!!!
running it in for proper operating temperature is not an option, i have no MOT!! >
Edited by Black_Pearl, 16 August 2006 - 01:09 PM.
Posted 16 August 2006 - 03:47 PM
Its one of them faults
Good luck
Posted 16 August 2006 - 04:41 PM
Tell us more.......
Posted 16 August 2006 - 09:36 PM
tell you more. rex patterson, father of gary patterson. together they won the last super mighty mini racing champsionship!! they own and race 'the green machine'. this car is like no other racer, it is immaculate and they only do it for pleasure! sponsored by minispares. the car was for sale on ebay but it didnt get the asking price for it so he isnt selling it. he wanted £6999 - if you had ever bought a car and you thought that you overpaid, this one is a guarenteed bargain. it has won the champship on more than one occasion. rex, gary and the green machine together are crazy. gary catches and overtakes miglias that start with 10+ secs ahead of them.
rex is a god, on our local forum (www.pandsmoc.com) his ranking under his user name is 'racing god' - totally true!!!
anyway thats enough of that!!!
tomorrow i got to change the engine managment loom. but first double check its earths as a very last resort!! grrrr
thanks again!!
Edited by Black_Pearl, 16 August 2006 - 09:37 PM.
Posted 16 August 2006 - 09:45 PM
Oh and that chaps user name on here is 'the old git'
Posted 21 August 2006 - 01:14 PM
You live all the way down south then near Poole?? Might explane your user name???
yup thats correct, thats his username is the old git on pandsmoc 2!! i live in gosport, nr fareham nr portsmouth!!!
turns out i have now changed all but everything in the engine bay. injector set up complete, ecu, lambda, loom, coolant sensor, lambda relay, map, vacuum hoses.
the lambda i bought was the one you suggested sprocket, on the spi faq threads - the bosch one.
i think it must be electrical as it cannot be anything else. i cannot see the problem being something like cat gone or too big of an exhaust. there must be a short or an earth somewhere!! im going to take it to a sparks on wednesday, hopefully he can fix it!!
