Electricial - Dynamo Giving Smoke...
electrical
16 replies to this topic
#16 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 January 2016 - 06:48 PM
If your not getting the voltages as per the tests then its time to look at the dynamo, as I said above any dynamo that is smoking has to be damaged on the windings, if it wont meet the voltage on the test then its time to seek a replacement. Have you thought about doing a conversion to a alternator
#17 mbinsaleem
mbinsaleem
  • 15 posts
Posted 22 January 2016 - 12:32 PM
Actually my car was already running an alternator, and now i am doing the conversion back to dynamo :D Thanks for your response, I would look into this hopefully soon, as have been busy last couple of weeks, and not much progress on the car...
I also ran some diagnostics on the control box, with it out of the car. If I connect a small battery's + end to the A terminal and the - end to the E terminal (via the voltmeter), I see a deflection of around 12-14V. When I run the same test with the - end of the battery connected to the D terminal on the control box, it still gives a similar reading (even with the cutout points separated manually). Is that how it should be?? I was thinking that probably on the 2nd test, it should not be showing any voltage reading (like when the - end is connected to the F terminal). Could you please guide on this...
