No haven't changed pressure plate .just replaced clutch plate.no haven't lapped anything and inside boss is good condition and have torqued up flywheel bolt to required value and seems to have gone back together as was?not sure what's causing this?
A common reason would be fretting causing small area's to weld due to high frequency vibration, these high spots may not be so obvious, but lapping the flywheel on to the crank tail helps to avoid them as the high spots a lapped away and you get more surface contact between the flywheel centre boss and the crank tail.
Or you haven't fitted it correctly on the dowels some how ?
Edited by MRA, 05 March 2016 - 08:18 PM.
