That's some good work you did there, but why did you have to do it ? Why was it so far out ?
I don't want to go to that extreme, I will get it as good as possible and live with it.
I'll be busy on it all weekend and let you all know what happens.
Pete.
They were second hand doors that came with the car. The car itself was straight although rusty as hell but I had replaced the full inner wings although the A posts themselves were OK. I had moved the window frame around a bit by using a block of wood and some large bars but it still did I not sit right. The door was gapped after a new skin was fitted etc so that was ok. I did have a few issues with that but considering I had replaced virtually the whole of both sides of the car it was not too bad.
If you have a look at a lot of minis you will see different gaps around the window frame, door gaps etc. I have very large gaps on my clubman. Now I know the car had been rear ended but had been repaired. Again I have changed everything from the bottom of the windows down and will be rest inning the doors properly.
You need to sort the A post to make sure that is straight then either replace the door or repair it. With the A post straight this will then position the door.
