You need to sort the A post to make sure that is straight then either replace the door or repair it. With the A post straight this will then position the door.
No, its the other way round, fit a good known door then adjust the A post, if you try to straighten the A post with a damaged door fitted how will you know the A post is in the correct position.
Out Of Shape Door Aperture
#31
Posted 06 February 2016 - 11:05 AM
#32
Posted 06 February 2016 - 12:31 PM
Try measuring the door opening, a tape rule will do, and comparing side to side.
#33
Posted 06 February 2016 - 12:37 PM
He already said there was damage to the A post so sorting that first surely should be the first to rectify. The door Defo needs to be either repaired or replaced. I know comparison maintenance is not always a good thing to do but I will chuck some measurements off a good door aperture and door at the OP to give him a fighting chance.
#34
Posted 06 February 2016 - 12:49 PM
The first is at the top of the A post where it then starts to angle back. Now this measurement is parallel to the door step and goes to the swage line on the quarter panel. 89.5 cms.
Second measurement parallel to the the door step and from the top hinge hole to the quarter panel is 96cms.
Third measurement parallel to the door step is top hinge hole lower hinge position 96cms.
The first measurement is from the aft edge of the A pillar, the next two measurements are from the hinge side of the A post. I have double checked these against the r/h side where I have physically replaced the inner and outer A post. Both identical measurements.
#35
Posted 06 February 2016 - 12:58 PM
This is on the inside of the door where the window frame exits the door carcass. 86cms.
Next measurement is on the door carcass inside and its from directly on top of the the door catch to the fwd edge of the carcass. 35"s
The same for the lower section.
Now the door skin edge to edge is 94cms directly below the door handle and to the centre of the top hinge the same measurement applies to the lower hinge as well.
#36
Posted 06 February 2016 - 01:04 PM
#37
Posted 06 February 2016 - 01:18 PM
I have been out and measured and compared both sides and as I said before, I have 1 cm less on the damaged side, and 1/2 cm too high too the roof
#38
Posted 06 February 2016 - 02:27 PM
I will back out now as the OP is getting conflicting methods and we don't want to confuse him.
#39
Posted 06 February 2016 - 04:55 PM
No don't back out at the end of the day all info helps. I fully understand where you are coming from about fitting a good door to see what has happened but also that damage on the A post on will need to be addressed as well.
#40
Posted 06 February 2016 - 05:54 PM
Right some pictures as mentioned earlier.
This is one i did a few years ago and forgot about it
Todays efforts, so this one is the top of the A post where it starts to angle back
The top hinge top hole
The lower mount top hinge hole
and where they relate to on the quarter panel
Inside the door, upper hinge
lower hinge
Externally
So hopefully these pictures will help to make sense of my previous answers. Sorry i did not take one of where the window frame enters into the main carcass of the door.
#41
Posted 07 February 2016 - 08:49 AM
Pete.
#42
Posted 07 February 2016 - 08:59 AM
Brilliant, thank you, I will get back to you all with what I measure. Thanks everyone.
Pete.
Glad to help, any more measurements I will be up the workshop the next few days.
#43
Posted 16 February 2016 - 09:57 AM
OK, so I've measured and checked and I'm about 5mm shorter front to back. BUT, I have now removed the scuttle and this is what I found
WP_20160211_003.jpg 24.67K 35 downloads
Sonnik4, could you measure left door lip to right door lip ? I don't think it's moved the door lip just this part at the front of the A post.
Pete.
#44
Posted 16 February 2016 - 03:40 PM
Pete.
Sorry Pete I won't be up the workshop this week. Unfortunately the mini I have in my garage has modified doors so it will not give you a true figure.
#45
Posted 16 February 2016 - 05:16 PM
Pete
