Front Suspension Top Pin Removal - Access Question
Best Answer Tamworthbay , 07 February 2016 - 04:15 PM
I think the spi rad is roughly the same in terms of access as the earlier ones. In which case you don't need to take it out. There is a little cut out in the inner wing and it takes a bit of a wiggle. Someone will be able to confirm 100% on the spi aspect but I think you will be ok. Go to the full post
Posted 07 February 2016 - 03:21 PM
1996 SPi, and I will be removing the front left suspension for a complete renovation including hi-lo (Already fixed the right side). Question is, do I need to remove the radiator to get the top pin out?
Posted 07 February 2016 - 04:15 PM Best Answer
Posted 07 February 2016 - 07:20 PM
And you need to hold your tongue in the right position.
Not the most pleasant of jobs.
Posted 07 February 2016 - 07:41 PM
Posted 08 February 2016 - 04:30 PM
I've been practising cutting my hands and swearing a lot. Hope that's going to help
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
