Hi;
Quick question, what size / grade bolts should be used for the the four bolts that go through the Toe Board into the Front Subframe.
1982 Mk4? 998 Saloon
They look like 5/16?
Edited by JonnyAlpha, 06 March 2016 - 11:14 AM.
Posted 06 March 2016 - 11:10 AM
Hi;
Posted 06 March 2016 - 11:37 AM
Posted 07 March 2016 - 07:25 PM
you mean in place off these
http://www.minispare...x?3~21~206|Back to catalogue
Ah interesting, mine simply has two bolts on either side, i'll dig out a pic, the original 'weldbolt plate' must have been replaced at some point.
The Minispares stainless ones look a lot better, pitty they'll be under the carpet
Posted 07 March 2016 - 07:54 PM
That saves you needing 3 hands to do them up
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
