Brr!
electrical
11 replies to this topic
#1 whittlebot
whittlebot
  • 58 posts
Posted 09 March 2016 - 05:37 PM
Is there a way to improve the heating in my Mini Mayfair. Input and heat. No matter how many hours I'm driving. I still only get a barely warm airflow.
Thanks in advance,
Jonathan
#2 hhhh
hhhh
  • 422 posts
Posted 09 March 2016 - 05:40 PM
Install a hotter thermostat. Make sure your coolant is fully topped up too.
#3 rally515
rally515
  • 3,848 posts
Are the rubber ducting seals doing there job ?
To be honest it's not a fantastic heater in the mini anyway, although your heater matrix could be struggling to flow the water through due to a blockage.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,074 posts
  • Name: Neil
Posted 09 March 2016 - 06:20 PM
Back flush the heater matrix, this should help to clear any grot however if the coolant mixture has never been checked and is a rusty brown colour then there is a good chance even back flushing will not sort it out. This will mean a new matrix and also possible a new rad.
My 74 clubby has a single speed fan heater and with its new matrix ( old one was leaking) it produces a lot of heat.
#5 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 09 March 2016 - 06:51 PM
Also make sure you bleed the cooling system properly.  :highfive:  IMO, you should not need to fit a higher temp thermostat, the standard item should produce enough heat, and cool the car efficiently.
#6 hhhh
hhhh
  • 422 posts
Posted 09 March 2016 - 07:25 PM
How do you know he has a standard thermostat fitted?
#7 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 09 March 2016 - 07:59 PM
Also the thermostat may be old and passed its use by date, in other words weak and opening too soon. That would be the first thing I would do. Replace it!
#8 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 09 March 2016 - 08:32 PM
Our SPi had the matrix blocked by dust, stopping airflow through it. Careful washing gave new warmth.
#9 travellering
travellering
  • 125 posts
Posted 10 March 2016 - 03:08 AM
Also, how solid is the mini? I have one that's several oxidation events past its last MOT, and so much air gets through the cabin that the heater can't keep up. Check your condition and fit of all your door seals, windowseals, and firewall plates and grommets. Just replacing the carpets in my rusty one made it feel ten degrees warmer!
#10 whittlebot
whittlebot
  • 58 posts
Posted 10 March 2016 - 07:35 PM
thank you for the tip and advice!
#11 whittlebot
whittlebot
  • 58 posts
Posted 10 March 2016 - 07:36 PM
Thank you for the advice and the tip. Think It may require more than the carpets!
#12 whittlebot
whittlebot
  • 58 posts
Posted 10 March 2016 - 07:37 PM
Thank you to everyone! My head is buzzing with things to try!!
Jonathan
