Hello,
When I have the car running everything is working fine, but when I turn on my headlights the speed and revs dials turn off/go to zero like the car has been switched off. This has only started to happen recently.
I noticed that on the back of the instrument panel assembly the printed circuit board had split in one place which stopped the indicated working, however I fixed that. I have also recently changed the front headlights but only replaced the bulbs not touched any wiring. Before I altered these the problem was still there.
Any help would be appreciated thank you.
(I have a 91'Rover Mini Cooper)
Instrument Panel (Speed And Revs) Drops Off When The Lights Are Turned On
EliottHolmes
, Apr 02 2016 03:51 PM
electrical
No replies to this topic
Mini Technical Sections →
Problems, Questions and Technical →
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
