Turn the adjuster dial back to soften the firmness.
I loosened the dial all the way so it extended as far as it went and then tighted it up. Would I have to loosen it and then push the shock back up to where it was?
Posted 11 April 2016 - 12:58 PM
Posted 11 April 2016 - 01:18 PM
NO.
the shocks have nothing to do with it.
the ride height will be the same with shocks fitted or removed.
it is your suspension you must look at.
Posted 11 April 2016 - 01:43 PM
All the dampers (shock absorbers) do is to damp out the springiness of the suspension spring. They have absolutely no effect on the ride height of the car.
The stiffness of the damping controls the way the wheels stay in contact with the ground, so on very smooth surfaces they can be set harder than when being used on bumpy roads. Adjustable dampers allow the road-holding to be optimised for different road surfaces.
The ride height is controlled by the spring height unless adjustable suspension (Hi-Lo's) is fitted.
To reset the damping after having it very stiff (say for a race track) is done by backing off the adjuster screws and then re-tightening them to the previous settings, or by using trial & error. Of course, it helps if when hardening the damping you actually count the number of 'clicks' you increase by, then you simply back off that number of clicks.
Posted 11 April 2016 - 02:09 PM
Edited by THE ANORAK, 11 April 2016 - 02:09 PM.
Posted 11 April 2016 - 02:12 PM
Edited by THE ANORAK, 11 April 2016 - 02:14 PM.
Posted 11 April 2016 - 03:27 PM
Imagine that dial as the brownness setting on a toaster. Turn one way, light toast, turn the other, dark toast. On the damper turn one way, soft damper, turn the other way, hard damper
yeah ok I get it. But im just saying to reset the shocks back to the way they were, then this is a starting point to getting it back to the way it was.
Posted 11 April 2016 - 03:39 PM
You really need to help us, help you.
As a start, when you turn the dial on the shocks, you will feel "clicks" or steps. Count how many there is and as a start set them all at the halfway point.
Now it is time to, look at why the car sits low. A key question which several others have also asked - Do you have Hilos fitted?
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
