1989 White Mayfair - Amateur Turbo Build
103 replies to this topic
#91 BudgieCake
BudgieCake
  • 79 posts
  • Local Club: Midweekminis
Posted 29 November 2021 - 07:23 PM
Two of my favorite mini threads updated, its 26 days till Christmas, whats going on ?
#92 jamesquintin
jamesquintin
  • 1,025 posts
Posted 30 November 2021 - 09:21 PM
Mines the other right...? 😅
#93 ben
ben
  • 95 posts
Posted 04 December 2021 - 06:57 PM
Great thread, just read beginning to end! Look forward to more updates.
#94 I hate Brian
I hate Brian
  • 782 posts
Posted 05 December 2021 - 02:24 PM
Great build whens the next update buddy ?
#95 MaxDempsey
MaxDempsey
  • 137 posts
Posted 03 February 2022 - 10:21 PM
Update: Once I got the car painted I wanted to throw some bits on to make it look more complete just to give myself some motivation really. Fit an old janspeed centre exit exhaust and the rear lights. After cutting and welding the turbo downpipe a few times I was able to get the exhaust to sit up quite well unerneath the car which I'm pleased with.
51860531426_e2e0826987_c.jpgUntitled by Max Dempsey, on Flickr
51859574942_049da0faca_c.jpgUntitled by Max Dempsey, on Flickr
I then built up the turbo and manifold to fit hopefully for the last time for a while.
51861184235_87d116aa5f_c.jpgUntitled by Max Dempsey, on Flickr
and made some barbs for water lines and vacuum hoses.
51860531501_fa4c974a21_c.jpgUntitled by Max Dempsey, on Flickr
51860864194_4627ab64bb_c.jpgUntitled by Max Dempsey, on Flickr
51860864234_72862c883f_c.jpgUntitled by Max Dempsey, on Flickr
51860614408_3444fa36a7_c.jpgUntitled by Max Dempsey, on Flickr
Turbo and inlet on with some solid steadies courtesy of go kart steering arms.
51860531531_17e64a9779_c.jpgUntitled by Max Dempsey, on Flickr
51859574927_5eb83f5878_c.jpgUntitled by Max Dempsey, on Flickr
I am now doing the wirng. Using a standard loom as a base but hacking it up a fair bit as I want it all hidden and my bulkhead clean of any holes.
51860614338_daa4a383d6_c.jpgUntitled by Max Dempsey, on Flickr
I'm fitting plugs where ever possible just to keep it all neat.
51860614343_d3228d9d00_c.jpgUntitled by Max Dempsey, on Flickr
So that's it for the moment. Hopefully have it running in a couple of weeks all going well.
Edited by MaxDempsey, 03 February 2022 - 10:22 PM.
#96 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 18 February 2022 - 02:31 PM
What a great thread  :-)  :mrcool:
#97 MaxDempsey
MaxDempsey
  • 137 posts
Posted 27 February 2022 - 08:39 PM
Been chipping away at this a bit more.
Got the tappets set first.
51906920977_e9290dd642_c.jpgUntitled by Max Dempsey, on Flickr
Then the fuel system all plumbed in.
51892290435_c9a437d2f6_c.jpgUntitled by Max Dempsey, on Flickr
Welded a flexi into the exhaust and then lashed up a mount to secure the downpipe to the diff housing.
51890679107_8aa8b9005f_c.jpgUntitled by Max Dempsey, on Flickr
51891636326_bef2099c15_c.jpgUntitled by Max Dempsey, on Flickr
51891725163_b8367cf62c_c.jpgUntitled by Max Dempsey, on Flickr
I bought a cheap lightweight battery off a recomendation from a mate and so far all seems well. Made some battery cables and fitted a battery cut off switch while i was there. Still need to secure the battery.
51891636341_661788afdb_c.jpgUntitled by Max Dempsey, on Flickr
51890679087_b7baf362d9_c.jpgUntitled by Max Dempsey, on Flickr
I cut the loom up a bit and converted to a centre ignition switch.  I then spun the engine over and got oil pressure up.
51908522950_9dd6c2b328_c.jpgUntitled by Max Dempsey, on Flickr
51890679132_3997ee6ff7_c.jpgUntitled by Max Dempsey, on Flickr
Finally I made some ht leads.
51890679127_03d6817c3e_c.jpgUntitled by Max Dempsey, on Flickr
So then after the carb float sticking and filling the engine with fuel  >_< I gave it a go and it started straight up.
51906949797_ecfa40f2c0_c.jpgUntitled by Max Dempsey, on Flickr
Everything seems okay at the moment for the most part. I havent got any ic pipes plumbed in at the moment but it runs happily enough. A mate came round and helped me with the megajolt software and got it idling alot cleaner. It seems a little smokey at the moment but hoping a run and a boot on the road will cure this (itll be a miracle if it does  :lol:
Only real issue was the crank pulley trigger wheel bolt hitting the rad cowling and machining itself away a little. Small tickle with the grinder and a hammer sorted this. Next job is to put the front on and work out an intercooler set up.
#98 Rocket.
Rocket.
  • 1,444 posts
Posted 17 June 2026 - 05:30 PM
Patiently awaiting an update, it’s been 4 years….
#99 timmy850
timmy850
  • 3,602 posts
  • Local Club: MITG
Posted 18 June 2026 - 08:08 AM
From the look of his instagram page it was running 3 years ago
#100 MaxDempsey
MaxDempsey
  • 137 posts
Posted 18 June 2026 - 06:46 PM
Right, here is the update, only 4 years late ahaha. The car is up and running. Not on the road this year due to trying to be sensible and save anything to buy a house.
But shortly after the last update it made it to the road. Since then its done a fair few miles, including a trip to the lakes, scotland, wales and the Nurburgring. Its also had various things on the roof and at one point was used daily for a summer.
Apart from blowing a headgasket 2 days before the ring trip (my fault for being too brave with boost) and little niggles it was fairly relaible considering the abuse it got and the miles it did. Here are some random photos.
55342268832_0366b9bdbd_b.jpgIMG_7844 by Max Dempsey, on Flickr
55343611170_6655cd1906_b.jpgIMG_7789 by Max Dempsey, on Flickr
55343611065_24a17e4841_b.jpgIMG_7861 by Max Dempsey, on Flickr
55343611120_5ef9410ffa_b.jpgIMG_3550 by Max Dempsey, on Flickr
55343611090_75f59f8b7a_b.jpg22b79702-7021-4423-940c-24a2f36188f2 by Max Dempsey, on Flickr
55343346893_d10ef04ddb_b.jpgDSCF3286 (1) by Max Dempsey, on Flickr
55342268777_031deffb96_b.jpgIMG_4311 by Max Dempsey, on Flickr
55343196421_2e47b6d39f_b.jpgIMG_4291 by Max Dempsey, on Flickr
55342268737_7c9eec8218_b.jpgIMG_4272 by Max Dempsey, on Flickr
55343346883_9534c900bf_b.jpgIMG_3678 by Max Dempsey, on Flickr
55342268752_72b866718a_b.jpgIMG_9613 by Max Dempsey, on Flickr
55343346868_f5a1029e78_b.jpg8588BB94-0095-42F2-8F69-914BEF99E4DC by Max Dempsey, on Flickr
55343411649_a8f713c87b_b.jpgceaeb45a-ec3c-41ec-903e-53ed88fc81a7 by Max Dempsey, on Flickr
55343196401_a7e8a70956_b.jpg654e594b-30ca-4ba8-9f4b-01d7aa74e1b7 by Max Dempsey, on Flickr
55343196346_a8b95b7b46_b.jpgIMG_3897 by Max Dempsey, on Flickr
55343346838_27180a4fc9_b.jpg4a6801f8-07aa-472b-be42-efca56856c3d by Max Dempsey, on Flickr
55343196351_b40081f7e1_b.jpg22229c48-c298-4b6c-addf-d481ba5168dc by Max Dempsey, on Flickr
55343346818_d2e0bb05db_b.jpgIMG_3512 by Max Dempsey, on Flickr
55343610940_096b398d62_b.jpgIMG_3508 by Max Dempsey, on Flickr
55343196326_cb14dfb926_b.jpgIMG_3493 by Max Dempsey, on Flickr
55342268702_7a3580ce58_b.jpg07ef25d5-e5ea-4805-829b-c5b43f916c4a by Max Dempsey, on Flickr
55343417779_f9afc203cd_b.jpgIMG_9436 by Max Dempsey, on Flickr
55343417784_e649d3850c_b.jpgIMG_9423 by Max Dempsey, on Flickr
55343417769_9b3cdccd4b_b.jpge1a79a39-9fc2-4bd3-aff3-27d1820c3d63 by Max Dempsey, on Flickr
55343417774_71168ae3c2_b.jpgIMG_7981 by Max Dempsey, on Flickr
Sorry it is all a bit random  :D
Edited by MaxDempsey, 18 June 2026 - 06:46 PM.
#101 lsto
lsto
  • 718 posts
Posted 18 June 2026 - 07:50 PM
Just read through this, well done, keep the updates coming 👍
#102 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 19 June 2026 - 07:44 PM
brilliant update! Looking great on those Archless steel wheels
#103 Rocket.
Rocket.
  • 1,444 posts
Posted 23 June 2026 - 08:40 PM
See you in another 4 years for the next update?
Also you have hair in those photos!
#104 BudgieCake
BudgieCake
  • 79 posts
Posted 24 June 2026 - 05:26 PM
Looks well max
55355171469_8d9240c8dd_b.jpgDSCF2548 by Thomas Barrett, on Flickr
55355128498_e54babd5d4_b.jpgDSCF2554 by Thomas Barrett, on Flickr
55354972176_b5227a4ff8_b.jpgDSCF2572 by Thomas Barrett, on Flickr
55355128488_cd7942e31f_b.jpgDSCF2664 by Thomas Barrett, on Flickr
