Overheated And Now I Seem To Have Problems
engine electrical
21 replies to this topic
#16 Baynton1991
Baynton1991
  • 19 posts
Posted 24 July 2016 - 07:46 PM
I'd probably start with a compression test. Best done when at running temp, but even done cold may shed some light.
Ye I will try and get hold of a compression tester from work tomorrow and see what that turns out to be.
#17 cal844
cal844
  • 9,643 posts
  • Local Club: TFMOC
Posted 25 July 2016 - 10:44 AM
its sounding so bad under load. Its fine in neutral through the rev range.
Headgasket then.
Could be the coil(I doubt it as the op adjusted the timing..)
Had a new coil few weeks back.
We bought a new coil for our 998 and it was faulty
#18 Baynton1991
Baynton1991
  • 19 posts
Posted 25 July 2016 - 04:52 PM
Headgasket then.
My thinking is its the overheating that has caused the issue as the engine was running fine before
#19 Baynton1991
Baynton1991
  • 19 posts
Posted 27 July 2016 - 07:38 PM
So I ended up just removing the head as I finished work early. Ive attached some pictures. Theres some marks in between cylinder 2 + 3. But hasn't completely broken through the gasket?
What do you guys all think?Attached File  13672493_10153760321456716_1148423867_n.jpg   56.33K   16 downloadsAttached File  13867003_10153760314841716_885101778_n.jpg   57.47K   15 downloads
#20 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 28 July 2016 - 09:42 AM
Did you do a compression test first? That would show if two and three had become one!
Lay a metal straight edge on the head face and check it hasn't warped from the overheating. Also check the block face is flat.
#21 Baynton1991
Baynton1991
  • 19 posts
Posted 28 July 2016 - 11:09 AM
Would've been waiting a week for postage of a compression tester and I was itching to see if it was the head gasket so I pulled it off. Yep will do. Now the carb is off i will give that a good clean as well and check for damage.
#22 Baynton1991
Baynton1991
  • 19 posts
Posted 28 July 2016 - 11:10 AM
but if it turns out not to be the cause I don't know what I'm going to do
Also tagged with one or more of these keywords: engine, electrical
