If its got fuel then check for a spark, if youve got a spark then you need to check for compression in cylinder.
The easyest way to check the ECU and sensors is by getting a diagnostic test set on it. That'll need to be done by a garage, unless you have access to one.
Have a read through this FAQ on SPI's. For some reason Mini Sproket has changed the colour of his writing to white, just highlight over it to read it.
alright mate thanks alot ill let u no what happens wiv it booked it in for thursday for the ecu 2 be checked do u no if they need the hole car?
liam
